wared manifold???
Old 11-03-2007, 04:22 PM
youngyota88's Avatar
warped exhaust manifold???
i have an exhaust leak on my 8822re engine. i dont know where it is coming from all manifold and egr bolts are tightened. is it possible that the manifold warped
Old 11-03-2007, 04:38 PM
Jay351's Avatar
Turn the truck on, and feel around the manifold/block and then feel by where the manifold connects to the exhaust pipe, and so on.
You should be able to feel the exhaust comming out.
If the gaskets are gone, tightening down the bolts will do nothing.
Old 11-03-2007, 04:50 PM
i have all tha gaskets on and i felt around but nothing still. i dont want to run it too long cause i might burn a valve on my newly rebuilt head
Old 11-03-2007, 04:55 PM
Jay351's Avatar
How bad is the leak?
you should be able to feel the exhaust from the leak.
Old 11-03-2007, 04:58 PM
i am positive its only on one cylinder but it sounds like i am missing a bolt or two around a port. is there anything i could use to help me find the leak
Old 11-03-2007, 05:00 PM
Jay351's Avatar
you could use a peice of paper or somthing, go around the manifold and see if it moves.. or somthing similar.
I recently did some exhaust gaskets on a 90 silverado, you could feel where the exhaust was comming from easily.
Old 11-03-2007, 05:09 PM
it doesnt make sense tho i have a gasket there and i just checked, nothing around the manifold and nothing around the back. i am stumped
Old 11-03-2007, 05:18 PM
CyMoN's Avatar
sea foam and have someone plug your tail pipe with their hand you will see the smoke from he sea foam come out from the leak
Old 11-03-2007, 05:32 PM
Targetnut's Avatar
get a long piece of vaccum hose (or other small diameter hose) and hold one end close to your ear. run the other end around the area of a suspected exhaust leak. You'll be able to hear where it is.
As far as burning a valve. Don't worry about that. If you ran at highway speed with no manifold on it, you might burn a valve. There is no chance of that happening while at idle.
Staff
DeathCougar's Avatar
Check your header pipe at the "Y" those things are VERY prone to cracking, especially if the support bracket that mounts to the transmission is MIA
Old 11-04-2007, 02:11 PM
well i fixid the problem. i took everything exhaust related and cleaned the parts and put it back togather. i dont know what it was or what i did but i fixed the problem. thnk you for the help
kawazx636
10-06-2021 03:03 PM
puddlepirate
07-30-2016 06:29 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
the_supernerd
10-01-2015 09:20 PM
kawazx636
09-29-2015 08:22 AM
Quick Reply: wared manifold???
