W56 Capacity
Old 12-24-2006, 08:39 AM
MMA_Alex's Avatar
W56 Capacity
I replaced the shifter seat bushing. I also changed the trans fluid, and poured it through the shifter hole to refil the trans.
I've put 4 quarts in, and i still cant feel any oil in what i believe is the fill plug. Does anyone know the capacity, or anything else that could be the issue?
Old 12-24-2006, 09:16 AM
Bill's Avatar
From my Haynes Manual:
4 to 7 pnts (fill to over flow)
I think I put about 4L into mine the last time I filled. The filler plug is on the side of the tranny: drivers side, just a bit forward of the shifter.
Old 12-24-2006, 09:37 AM
MMA_Alex's Avatar
its on the drivers side? I thought it was the 22mm plug on the passengers side. I'll check the smaller bolt on the drivers side and see if anything comes out.
Old 12-24-2006, 10:05 AM
MMA_Alex's Avatar
I tried at the plug on the drivers side. wont move. Its a 17mm, and seems to be slightly behind the shifters. The 22mm plug i removed, and thought was the fill plug is actually directly between the trans, and t-case shifters on the passengers side.
Im guessing the trans is full with 4 quarts in it, but I still would like to check that its properly filled through the correct fill hole. Does anyone have a picture of the correct fill hole?
Old 12-24-2006, 11:18 AM
4Crawler's Avatar
3.2 qts. according to my '85 Owner's Manual (W56A):
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
Fill hole on mine is right next to the reverse light switch.
Old 12-24-2006, 11:43 AM
MMA_Alex's Avatar
the hole next to the reverse light switch is the one I tried thats a 17mm, but cant manage to get loose. I guess Ill go try it again thanks.
Old 12-24-2006, 01:16 PM
toyota_mdt_tech's Avatar
I bet you are about a 1/2 qt away.
Old 12-24-2006, 03:03 PM
waskillywabbit's Avatar
I'd invest in a FSM or a Haynes/Chilton for things such as this so you have it on hand.
On my 85 the tranny fill was on the d-side in an awkward spot, so that is why I filled it through the shifter until it came out the fill hole. Seems like it was between 3 and 4 quarts.
Old 12-24-2006, 03:19 PM
MMA_Alex's Avatar
Got it now. It was the 17mm plug near the reverse light switched as described.
The issue was that I expected it to be a 22mm plug like the rest of the fill/drain plugs on the truck are. There is a 22mm plug on the passengers side, and I thought it was that, but that seemed rather high in the trans to be the fill hole. I dont like haynes and chilton because they tend to just generalize this stuff, and provide few details about how where to actually find things.
It was indeed between 3 and 4 quarts, and I hope that in the future someone who needs to know this can find this thread (I couldnt find any threads on the capacity of the w-56).
The following 2 users liked this post by MMA_Alex:
Cole1985 (05-30-2021), Genera_lee (11-01-2020)
justdifferentials
14
06-11-2017 08:36 PM
toyotasaurus
09-24-2015 03:30 PM
Jake28296
09-16-2015 06:10 AM
JAmdor3
08-11-2015 10:53 AM
89hilux1
07-19-2015 01:32 AM
Quick Reply: W56 Capacity
