| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Volvo electric fan install
#2 (permalink) |
Deffinately want to see this.
__________________
89 v6 SWB truck *PROJECT "BLACK BEAUTY* P&P heads, EB's OS SS valves,30 over on the bottom and deckedto zero, taurus fan mod. |
#3 (permalink) |
finally got my camera back!! about damn time i know! here are the pics
as far as doing this, just follow the writeup in the tech section, then look how i cut the shroud for second gens. the ac idle up was no good, it also is switched to ground. i guess ill try the compressor clutch next, then after that i have no idea. i have a pic showing where i mounted the controller, but i need to edit the fender sticker vin# out!! ****SEE BELOW FOR PICS**** Last edited by motoracer47; 07-06-2006 at 05:26 PM. |
#4 (permalink) |
That's AWESOME that you got it to work and took pics of the back side of the shroud. If I ever take mine off, I'll take more detailed pics. I only had to trim the "tabs" off the volvo shroud to get it to fit in the 3rd gen shroud - so 3rds have not only a lager radiator, but also a deeper shroud.
#5 (permalink) |
thanks! yea the 3rd gens must have a much deeper shroud, especially at the bottom.
(btw, i edited my first post to spell your name correctly, oops
#6 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#7 (permalink) |
I'd like to see tham as well
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#8 (permalink) |
sorry, i dont know what happend to the pics, ill get them back up, but i didnt do anything to them, maybe pictiger has a time limit for non paying users, who knows.
#9 (permalink) |
Just use the attachment feature here. That way they won't disappear...
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#10 (permalink) |
Wow, you mean we don't need a host server to post pics here?
__________________
#11 (permalink) |
Pics!!!!
__________________
-Chris Tread Lightly! 04 Double Cab PreRunner. 3.4 - Auto 84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50 Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris Great Toyota Tech |
#12 (permalink) |
![]() ![]() ![]() btw, the wiring for the controller was cleaned up, that pic was after initial install |
#13 (permalink) |
Looks great, all you do is cut the plastic and bolt it to the stock shoud, eh.... I think I may do that next spring when the motor is out for the rebuild.
__________________
#14 (permalink) |
It does look nice, sounds like it is way more entailed than the 3.4 though. Good write up, and nice pics though. nice work man.
__________________
#15 (permalink) |
thanks
i think the only thing that makes it tougher than a 3rd gen is the amount of shroud cutting, everything else is the same. heres a pic of the cut shroud pieces, should give an idea of how much you gotta cut. the main problem is the 2nd gen shroud is much shallower than a 3rd gen, which requires alot more plastic removal from the volvo fan shroud as to not hit the radiator.
#16 (permalink) |
whew, thats a lot of shroud. Very nice work though. I know a lot of guys will appreciate this.
__________________
#17 (permalink) |
thanks, hopefully it helps people out. we should also thank bamachem, he did the main write-up on this mod(if others did it first, my bad, bamachems is the only one i know of) and without his write-up, i never even would have known about the mod, thanks again bamachem
#18 (permalink) |
Super Moderator-Sponsoring Member
Staff
Does the dcc controller hook up to the higher speed on the Taurus 2 speed fan? (I assume).
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#19 (permalink) |
im not sure waskilly, im using a volvo fan. maybe someone else knows? if its a relay thing, i think you would get rid of the relays, as the dcc hooks up directly to the 2 leads for the motor.
#20 (permalink) |
Staff
I got it figured out. Thanks.
__________________
#21 (permalink) | |
Sorry for the thread revival guys
Quote:
Did you ever get this fan running right? or at all? When you are talking about 3rd and 2nd gens in here, are you talking about 4runners? or trucks? Just curious (my truck is a '93, so 3rd gen depending on who you talk to) Did you install this on your rig, and if so how did it work out? towing? in town? stop and go traffic? etc. etc. any details are appriciated I've been looking to go with an electric fan for a while, and wasn't too keen on paying $$$ for a flexi-crap, or putting anything from a ford on my toyota (not that Volvo or whoever owns them now is any better) Sorry guys, I'm not a purist, just picky. Here is the write up thread for this mod for anyone too lazy to search: http://www.yotatech.com/f2/electric-...stalled-61008/
__________________
. As well as fear, Chuck Norris can also detect hope. For example: "I hope I don't get a roundhouse kick to the face from Chuck Norris." . . 1993 Ex-cab 4x4 3.0 5spd, 155xxx mi. and counting, AND YES, IT DOES HAVE A TAPE PLAYER |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Electric Fan | amdman | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-28-2009 09:15 AM |
| stock fan & electric fan?? | bigpest88 | 86-95 Trucks & 4Runners | 14 | 08-03-2006 04:05 PM |
| Flex fan question. NOT flex-a-lite/electric fan | hockeytown9 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-12-2005 03:34 PM |
| is it worth the money and time to install Electric fan on 4Runner ? | fs8459 | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 01-17-2005 01:48 AM |
| electric fan | nigeltufnel3 | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 04-14-2004 07:02 AM |
