Vibrations: Rear diff companion flange?...
Old 10-27-2010, 05:23 AM
dhall50's Avatar
Question Vibrations: Rear diff companion flange?...
So I am trying to track down a bad vibration I get around 35-53mph. Makes my trans wiggle and my bed shake not to mention the rest of the truck. I swapped drive shafts and that made no difference.(I have two new joints to put in my old shaft for preventative maint but they are not bad right now.) So I read a little about companion flanges. I removed my drive shaft and the transfer case flange had not play that i could tell. The rear diff flange has very slight play up and down and I am hoping this is my prob simulating a bad U joint.
Where do I go from here? Could the flange nut be loose? Do I just put the E Brake on and re torque it?(90ft lbs?) I am not even sure how to un stake it. If that doesn't fix it how big of a problem am I in for? Thanks
Old 10-27-2010, 05:59 AM
waskillywabbit's Avatar
Factory Service Manual
www.ncttora.com/fsm
Rear pinion seal/bearing
:wabbit2:
Old 10-27-2010, 06:40 AM
4Crawler's Avatar
Info on un-staking and torquing pinion flange nut:
- http://www.4crawler.com/4x4/CheapTri...eal/index.html
I find a loose flange tends to vibrate only when backing off the throttle, when there is no load on the driveline.
Also check the shaft alignment and phasing:
- http://www.4crawler.com/4x4/CheapTri...n-Measurements
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
Old 10-27-2010, 10:10 AM
dhall50's Avatar
So after reading it looks like a ton of work just to replace that bearing and the torque mentions 173ftlb for a 7.5 and 253 for an 8". Seems like a lot. Probably way beyond someones ability that hasn't touched a diff before? Can I not just re torque that bolt without measuring preload etc to make sure it isnt just loose like others I have read about here?
Old 10-28-2010, 05:41 PM
zwhiz's Avatar
Location: where the left turn should have been taken, NM
so i had that same vibration that you are talking about and i ignored it for a month or so... about two weeks ago my diff made some terrible noise and grinding and started to lock up. i barely limped it home. i finally got to tear into it today...found my pinion bearing and seal were blown out...bad... here are some pics of the carnage
the gears on the left i pulled out of the third you can see its gouged pretty bad
bearing was just a mess....
Old 10-28-2010, 05:42 PM
zwhiz's Avatar
i'll let you know how replacing it goes....
just dont let it go too long and have what happen to me happen to you!
Old 10-28-2010, 05:55 PM
dhall50's Avatar
Yikes. A buddy came over and we looked at the flange and he concluded that since all of the play was in the flange and the shft itself was not moving that it was maybe just loose. We unstaked the nut and it was easy to turn. Re torquing it removed the play at least for now. I have been dealing with this for a long time. I still have misc vibrations but this was a big help. Interested to see if it lossens up again. Let me know how it goes.
PS: My buddy said a used 3rd member goes for like $75 at the junk yard? I will prolly go that route if mine continues to give me issues.
Old 10-28-2010, 05:59 PM
zwhiz's Avatar
ohh nice. youre lucky then! i just procrastinated until my exploded.... ya when i took mine off the flange nut was hand tight, not good. that was probably the root of my problems.
oh believe me ive look at junkyards for the last two weeks. every yota had the 3rd member pulled at u-pull-it and other junkyards wanted 250 for just the 3rd.
Old 10-28-2010, 06:41 PM
dhall50's Avatar
Whoa!
Old 10-28-2010, 07:53 PM
foutz's Avatar
Mine did the same thing but it would start when i would take off and stop at about 55. The nut backed all the way off and eventually the flang came completely off.
Old 10-28-2010, 08:01 PM
zwhiz's Avatar
daaang thats kinda scary
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
jaretstuff
08-04-2015 02:08 PM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Vibrations: Rear diff companion flange?...
