Vibration during acceleration
Here's my dilema got my first yota about a month ago. 95 v6 automatic. Last week i noticed vibration whenever i accelerated. The truck needed it regardless so i replaced plugs, wires, cap and rotor and fuel filter with no success. I did a little research and it pointed to my u-joints. I noticed to in my owner manuel and on my driver side sun visor there is a routine maintenance schedule for u-joints. I just want to know if i am on the right track any help would be greatly appreciated. thanks, Eddie
How are you going to rotate the drive shaft with the rear tires on the ground and the e-brake on? If it is doing in on accelleration day to day I am guessing it is the rear shaft not the front since it isn't spinning.
even checking in park isn't a bad thing. you're looking for slop in the u-joints after all, not in the park pawl, etc.
You're looking to see if you can rotate the driveshaft itself more than you can move the output shaft of the trans / t-case and input to the rear diff and see any play there.
hiluxinargentina
09-30-2015 05:51 PM
Odin
09-26-2015 06:56 PM
01, 2005, 2006, 4runner, 4x4, accelerating, acceleration, accelleration, durning, exceleration, jumpy, sound, toyots, truck, viberates, vibrates, vibrating, vibration
