Vibration!
Old 02-12-2009, 08:06 PM
toyotanick's Avatar
Vibration!
ummmmmm i think i might have a bit of a problem. i went climb some stuff and had a bit of hopping happen. ever since then i have a bad vibration when i first take off... anyone have n e idea? idk if it could be u joints but i sure as hell hope it is!!!
thanks for any help that you can give me!
Old 02-13-2009, 05:31 AM
toyotanick's Avatar
noeone has any ideas?
Old 02-13-2009, 07:57 AM
22mr2's Avatar
it does sound like a u joint or if you were really working the clutch, the disc may be glazed or warped. Id shake down the driveline first.
Old 02-13-2009, 04:51 PM
toyotanick's Avatar
alright, thanks ill give that a shot and get back to you
Old 02-14-2009, 08:26 AM
papadekaitlyn's Avatar
Check the transmission mount too while you're under there...
Old 02-15-2009, 07:22 PM
toyotanick's Avatar
for a shake? allrighty
Old 02-16-2009, 10:44 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I started getting "chatter" when pulling out of first and it appeared to be cause by my tranny bolts being loose/gone. The vibration was being cause by the engine and tranny seperating. Make sure you havent had some bolts trying to play David Copperfield on you.
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
4Xtruck
16
09-24-2015 09:38 AM
tinigunner11
08-14-2015 01:19 PM
Quick Reply: Vibration!
