Very Wierd Idle... PLEASE HELP!!!
So I have a 92 Yota pickup with a modified 22re and the Idle is acting up.
Modifications:
block shaved alot, pistons slightly above block.
head ported and polished, oversized valves.
dual pattern lobe 260 duration 420 lift camshaft
lc adj. cam gear
pacesetter 4 into 1 header
MAF enriched 4 clicks.
So it idles around 1500 rpms, with the idle screw all the way down. When I put my foot on the brake it lopes from normal back to 1500. Heres a kicker, when I put it in 4wd it does not lope at all, it stays at the constant high idle.
I have been trying to figure it out for 3 months now and nobody has a clue.
Modifications:
lc adj. cam gear
Seriously? Seems like 20 click is a real boat load. Could that indicate anything else, like the AFM spring is getting weak or the wiper that the flapper moves is hitting an oxidized spot?
I have the exact same issue on my 93 22RE 4WD. I adjusted the idle to where I can't go any lower. Sometimes it idles ok, but other times its high and/or high and low simulataneously when I press the brake pedal. I get 21 mpg, but I think it could be better. What do you mean by clicking the MAF? Thanks. DJ
Well, that's just odd. My engine is idling bad and it's got some new, some old. The long block is mostly new, in fact it's all new. But my sensors and intake are old. My AFM is not adjusted yet and I have Engnbldr's RV head with O/S valve, his 261 cam, a LCE header, clean injectors and all that. So I'm wondering if my ECU needs the AFM to be adjusted, too. Guess I'll try doing that afterall. All my sensors check out OK by the book, so I don't think I have a failed part anywhere, but I'm wondering if the AFM gets weak over time. That click wheel is adjusting the preload on a spring that holds the flapper closed, right? Maybe that spring gets old and with the higher air flow the flapper isn't moving smoothly, like it's fluttering or something, which confuses the ECU. I'm just grasping at stars trying to explain it.
Here is what I think is going on. I now have an engine that can pull air in better than a stock one (ported head, over sized valves, BIG cam, header) At idle, the mass air sensor is seeing more air being pulled through than it normally would. The ECM doesn't expect that much air flow at idle and tries to compensate.
All I did was tighten the spring on the MAF about 15 clicks, or just enough to make the idle even out. I checked all of my sensors and looked for vacuum leaks. Everything checked out. With it adjusted, I now have more low end torque than before. Just make sure you don't lean it out too much. If you smell the exhaust and you eyes start burning and it smells really sharp, then its too lean.
Doing this will only help if there is nothing else wrong with your engine. But if you want to do it anyway, just mark the stock setting in the MAF and you can play all you want to. (Learned the hard way on my Corolla)
Yeah, Zealot, your situation sounds a heck of lot like mine. Haven't been able to find a vacuum leak (still replacing hose, but nothing bad so far). Sensors are all testing OK, no ECU codes, etc. I have a RV head with O/S valves and larger combustion chambers, LCE header, good exhaust, 261 cam. What makes me think that my problem is a confused ECU, too, is that when I turn the A/C on, the idle smooths out even if I adjust the idle-up valve not to actually increase the RPM. So the engine is idling rough at 1000 RPM and I kick the A/C on, the idle doesn't jump above 1000 but it smooths out. Maybe the increased load on the engine makes the ECU give it more gas. I do think I'm running lean, too. It sure smells to my very uncalibrated nose like I'm lean at least (but it's been 7 years since I drove a truck with a carb, so I could be triggering faulty memories).
I'm looking for info. I have been fighting a similar idle issue and have a bad smelling exhaust. I thought it was running rich, didn't know a lean condition caused bad smell.
Also, I tested the temp sensor located at the front of the intake (truck won't run when unplugged) and want to see if anyone in this forum knows if my results are normal. I took only 2 readings. Cold = 3.4 K ohm & Normal oper temp = 0.2 K Ohm. I read some where that cold should be 1.4 and warm should be 0.2.
Not to be redundant (I posted my fix on another thread), but just in case my fix helps someone else. Everyone says look for vacuum leaks, and I found one. All problems went away when fixed. Hose was barely attached and letting a lot of unmetered air through.
robbieracer
7
01-17-2005 12:40 PM
Cebby
09-30-2004 04:29 AM
