valves or bad injectors?
Old 04-09-2010, 11:54 AM
norcal707's Avatar
hello there, I just finish putting my 95 4runner with the 3vze engine together after replacing the headgaskets and now it is making this clicking noise on the driver side, however, I have read that the injectors can make a clicking noise. when I was putting it together, i found out that two injectors green cap were broken but because I just wanted to have the vehicle running, I put the injectors without the caps....injectors without the cap can cause this noise or bad valves?
Old 04-09-2010, 11:58 AM
norcal707's Avatar
can anyone see a video
Old 04-09-2010, 12:00 PM
norcal707's Avatar
sorry
Old 04-09-2010, 12:03 PM
norcal707's Avatar
http://www.youtube.com/watch?v=E7E4c...layer_embedded
Old 04-09-2010, 12:11 PM
norcal707's Avatar
http://www.youtube.com/watch?v=oZGFxVDBqUk
Old 04-09-2010, 07:38 PM
OutlawMike's Avatar
As far as the pintle caps go, they really would have nothing to do with a clicking or tapping noise. The caps are there for protection of the nozzle and usually help hold the O-ring on.
Get yourself an automotive stethoscope to diagnose the injectors or the valves. Did you check the valve clearance before buttoning it up?
Old 04-10-2010, 05:25 AM
norcal707's Avatar
thank you mike but the 4runner blown another gasket last night. as you can see on the pic. it is from cylinder #6. leaks water into the cylinder and outside.
Old 04-10-2010, 05:45 AM
norcal707's Avatar
here is a short video.
http://www.youtube.com/watch?v=ZyLuK-Apm_U
raptor510
02-17-2017 07:11 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
keithporter83
07-18-2015 12:37 PM
sojourner567
07-16-2015 08:52 PM
Quick Reply: valves or bad injectors?
