valve tap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-25-2008, 11:31 AM   #1 (permalink)
joshuapc's Avatar
valve tap
i have a 90 pickup with a 22re. theres a weird tapping sound that seems to be coming from m valve train. the noise increases with higher rpms. i tried the lucas oil stabilizer, it helped a little. any suggestions on how i should approach this problem?
joshuapc is offline
Old 02-25-2008, 11:33 AM   #2 (permalink)
have you adjusted the valve lash? do a search on valve adjustment, and you'll find a ton of info.
MMA_Alex is offline
Old 02-25-2008, 01:44 PM   #3 (permalink)
joshuapc's Avatar
no i havnt adjusted it yet. just lookin for sum suggestions before i take apart my engine. would any body recommend some other mods or sources of the problem?
joshuapc is offline
Old 02-25-2008, 02:00 PM   #4 (permalink)
Targetnut's Avatar
If you think you have a valvetrain noise the first thing to do is to check the valve clearances and set them to spec.
While you have the valve cover off you can inspect the timing chain and guides
And when it goes back together, don't overtighten the valve cover nuts as this will make the valves noisey.
__________________
Targetnut
don't talk about it, just do it!
Precision Import Service
'93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate
Targetnut is offline
Old 02-25-2008, 02:16 PM   #5 (permalink)
jason191918's Avatar
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
Fuel Injectors?
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR | Blinker Mod
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is offline
Old 02-25-2008, 02:57 PM   #6 (permalink)
keithguts's Avatar
Send a message via AIM to keithguts Send a message via MSN to keithguts Send a message via Yahoo to keithguts
Quote:
Originally Posted by jason191918 View Post
Fuel Injectors?
I 2nd that as this was my problem. I also no that if the valve covers are to tight, it will cause tapping as well.
__________________
IF YOU DON'T DRIVE A TOYOTA, TEST DRIVE ONE TODAY!
MY PICS
95 4runner 3.0 auto 4x4
My Rig
My Rig
RangerMan
Enjoy
keithguts is offline
Old 02-25-2008, 05:06 PM   #7 (permalink)
joshuapc's Avatar
thanks a lot for everyones suggestions! damn things irritating!
joshuapc is offline
Old 02-25-2008, 07:28 PM   #8 (permalink)
joshuapc's Avatar
what do you mean by fuel injectors? they make a tapping noise?
joshuapc is offline
Old 02-28-2008, 09:11 PM   #9 (permalink)
when you guys say that over tighting the valve cover bolts can cause taping...how does that work? just curious
__________________
1-1988 toyota truck xcab, 3"bl, new paint, cold air,
soon to come-bj spacers, new 2" lifted rear springs.
turner01 is offline
Old 02-29-2008, 02:02 PM   #10 (permalink)
the rocker arms tap on the shield thing inside of the valve cover.
MMA_Alex is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
VALVE TAP .. distracting and embarassing Itoyota 86-95 Trucks & 4Runners 77 10-29-2007 02:51 PM
Valve tap on cold start? Doug S 95.5-2004 Tacomas & 96-2002 4Runners 2 04-17-2007 07:09 AM
Valve Tap MMA_Alex 86-95 Trucks & 4Runners 16 02-22-2007 09:08 PM
OMG What happend? - huge power loss, no oil, CEL, horrible valve tap... Starbuck3733T 86-95 Trucks & 4Runners 13 02-05-2007 11:36 AM
New engine noise (not valve tap or chain rattle) toymotaman 86-95 Trucks & 4Runners 7 02-18-2006 08:34 AM
2009 InternetBrands, Inc.
