| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Valve sticking
__________________
1988 p/u 4x4 22re- parked and dead =( (floped'er) The New-1988 p/u ex-cab 4x4 22re SR5 I think it has a 2" inch lift? rancho's. a jerry rigged cat-back and in the future: Rebuild with prefomance head intake,exsahst front bumber some tube doors,cb Last edited by davo247d; 11-08-2009 at 05:49 PM. |
#2 (permalink) |
Just curious, but how do you know that the valves are sticking?
__________________
1987 Pick Up 2.4L 4x4 2004 Rallirt 2008 Taco |
#3 (permalink) |
pulled the valve cover off and the springs were compressed
__________________
1988 p/u 4x4 22re- parked and dead =( (floped'er) The New-1988 p/u ex-cab 4x4 22re SR5 I think it has a 2" inch lift? rancho's. a jerry rigged cat-back and in the future: Rebuild with prefomance head intake,exsahst front bumber some tube doors,cb |
#4 (permalink) |
should i run a litttle sea foam? any sugestions? any help would be very much apprecieted!
__________________
#5 (permalink) |
i ran half a bottle seafoam in my engine and a whole bottle in my gas..my truck sounded much better and felt different in a good way..
__________________
#6 (permalink) |
If you just had the head off and hot tanked, I doubt SeaFoam will help your problem as you shouldn't have enough sludge or carbon buildup to interfere with valve operation that fast.
What else did you do to the head? Sounds more like a mechanical interference issue to me. |
#7 (permalink) |
What do you mean the piston will unstick the intake?
Did you have engine and cam positioned at TDC when you installed the rocker assembly and tightened the head bolts? If cam and pistons were out of sync you may have bent a valve. Did you align your timing chain with the marks on the cam and crank sprockets?
__________________
1986 22R 4X4 pickup. Currently rebuilding the engine. |
#8 (permalink) |
ya i alighned everthing up and all that jazz and the psiton will come up and give it enough force to un-compress the valve spring (with valve cover off and manualy cranking the engine) or i could take an extension and tap it on the spring and it would also decompress, ive been told by my fasha to use some carb spray on it and crank it by hand then spay it and repeat a few times but i still dont know
__________________
#9 (permalink) |
Your fasha...I guess thats gold member for father.
#10 (permalink) |
^correct haha
__________________
#11 (permalink) |
Like I said above, you have some sort of mechanical interference problem. Tear that head off and replace your valve(s). Maybe even valve guides and seals...
#12 (permalink) |
That's kind of what i'm thinking too...
i'd inspect your pistons, too.
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5 1978 Camaro Z28, 454 Big Block V8 with a 4 Speed. |
#13 (permalink) |
un fortunatly thats what i miight have to do but ive got another head and ill rebuild that one and throw it on i guess
__________________
#14 (permalink) |
I was gonna say; even though I am no mech, and though I totally love the Seafoam treatment trick; I don't think this is going to help you here!!
#15 (permalink) |
Mr seafoam spreading the love,or not.
#16 (permalink) |
it didnt so i think im gonna have to pull the head off again
__________________
#17 (permalink) |
For what most shops charge, its well worth having a machine shop inspect a block or head(s) any time you pull them. They have the right tools and tons more experience than most do-it-yourself mechanics (including me) can hope to.
![]() Once you find a good shop they are worth their weight in gold! ![]() They do a much better job of cleaning them for cheap too!
#18 (permalink) |
ya lol im just really short on money but ill have the head probibly all done today
__________________
#19 (permalink) |
so i got the head pulled and stuff well thepiston has a small dent in it =( but idk
![]() ![]() here is the bad valve can you see whats wrong? Here is a good valve for a hint The stem seal isnt where its suppose to be ![]() Can you see which is the bad valve (the right one) ![]() and its kinda hard to see but there is a small dent in the top of the piston from the exsuast valve (spelling i know) so what do ya all think?
__________________
#20 (permalink) |
I'd talk with a decent machine shop, but I can't imagine that little dent being a problem, curious to see what others think...
#21 (permalink) |
The ding on the piston does not look severe enough to be worth replacing the piston over. One might want to debur any sharp edges at the ding. The valve that got tagged is another matter. The head of the valve is likely bent enough to prevent a good seal and should be replaced.
I agree that the valve stem seal was off the guide, but I don't see this being the cause of the valve piston interference. You need to understand the cause of the problem and correct it. Eugene |
#22 (permalink) |
well i have another head that i got rebuilt and put on so im not even gonna use that head i might just scrap it idk
__________________
#23 (permalink) |
and it was sticking open causeing the interference
__________________
| Tags |
| 22re, engine, intake, rebuild, seafoam, sticking, toyota, unstick, valve, valves |
