Valve Adjustment/Knock question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-06-2009, 03:37 PM   #1 (permalink)
Booosted Supra's Avatar
Send a message via AIM to Booosted Supra Send a message via Yahoo to Booosted Supra
Exclamation Valve Adjustment/Knock question
I was reading on PG.35 on this for specs and I just had to questions I wasn't sure of that I could not find on any other threads from the past.
http://www.ncttora.com/fsm/1993/engine/7cylinder.pdf
1) After all valves are adjusted should they all be tight?
2) What is the purpose of the spring next to the rockers?
The problem I am having with a truck is that the top end is REAL noisy and at TDC the cylinder 1 rockers are very loose which seem to be far out of spec and the number 4 are tight but some of them you can move side to side. Is that normal? I just don't understand the side to side play. Something is def up with the top end, there is a lot of fine metal shavings up top but the pan is dropped and bearings all check out fine to the eye and its not a piston slap I disabled 1 cylinder at a time when running to see if the knock would go away. I'm going to hook up a oil pres gauge and compression test it next, but I'm almost positive they will check out. Previous owner did timing chain and guides which was obvious for me since half of the worn out old guides were in the pan. Any ideas?
And I did find the specs you guys were talking about for cold .007/.011
__________________
1994 Toyota 4Runner SR5: 36x12.5 TSL, 2` OME coils, 1.5 Sdori BJ spacers, 2` Rear Sdori coil spacers, OME nitro charged shocks, 1` custom body lift, Light Tbar crank, ISR mod, EGR block off, ARB bull bar, 5.29/Detroit locked
1989 Toyota Supra: T60 @ 22PSI 11.8, Apexi AFC, HKS VPC w/550 chip, RC 550 injectors, Lexus V8 mas air, Extreme PSI FMIC, HKS 50mm WG, Greddy type-r bov, Aeromotive AFPR, J tube block off, Fuel pulse removal, Walbaro 255h, LM-1 wideband, Unsprung 6 puck, Gutted 2900lbs
Booosted Supra is offline
Old 11-06-2009, 07:02 PM   #2 (permalink)
annoyingrob's Avatar
You need to adjust the valves in 2 stages. At #1TDC, the intake and exhaust on#1 should be adjusted and I THINK the intake on 2, and exhaust on 3. Then you turn the crank 360* (rotating the cam 180*), and do the others. If your rockers ar "very loose", they need adjusting. There should be just a tiny amount of movement in them.
I believe the purpose of the spring is to keep a little tension on the rockers to keep them from bouncong around a lot, but I could be wrong.
While you have the valve cover off, check the tension on the timing chain. A loose chain will make a ton of noise too.
__________________
86 SR5 Turbo pickup Fiberglass bed, Fiberglass Fenders.
91 1.5JZ GT40 Supra.
77 Celica Liftback. (WTB: 20R Carb!)
annoyingrob is offline
Old 11-06-2009, 07:13 PM   #3 (permalink)
Yodaforce's Avatar
They do have to be adjusted in sequence. A regular Haynes manual lists the sequence and the specs. The rockers will be loose even after adjustment. I'm wondering though if the noise you hear is a timing issue and not rockers. Rockers that make noise are 'falling off' loose, but incorrect ignition timing will make it rattle alot.
__________________
"Diverse-Customs" Hot Rods, Street Rods, Custom audio and video installation, sheet metal fabrication, tube work, bumpers, lift kits, just about any kind of custom work imaginable!
Visit us at Diverse-Customs.com
Yodaforce is offline
Old 11-07-2009, 05:51 PM   #4 (permalink)
Myron's Avatar
Send a message via Yahoo to Myron
How do you know which one is the number 1 piston. Does it go from front to back?
I forgot how to tell or maybe im getting confused with firing order
piston
1 2 3 4
__________________
1987 Pick Up
2.4L 4x4
2004 Rallirt
2008 Taco
Myron is offline
Old 11-07-2009, 05:55 PM   #5 (permalink)
peapicker's Avatar
yep, the one closest to the rad is num one. Could be wrong but I thought as long as the valve was set while on the back side of the lobe it is ok? the loose spot.
peapicker is offline
Old 11-07-2009, 07:05 PM   #6 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
piston
1 2 3 4
#1 is closest to the radiator and #4 is in the back.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 11-07-2009, 07:07 PM   #7 (permalink)
Quote:
In general, if the rocker is on the back side of the lobe it is okay, but to guarantee things are to spec, the valves should be adjusted one cylinder at a time with the cylinder at TDC of the compression stroke. This ensures that odd or more radical profile cams aren't ramping up to open or have just closed a valve and may be 'loose' but not completely clear.
__________________
Old 11-07-2009, 07:17 PM   #8 (permalink)
1) Valves should only be tight if the cam is applying pressure to the rocker, i.e.: the valve is being opened or is closing. At any particular time, some of the valves will be loose and others will be tight.
2) The primary purpose of the spring is to hold the valve closed. On our engines it also provides the force to close the valve as the cam rotates past full lift (opening) of the valve.
There should be some ability to 'slide' the rocker arms along the rocker shafts but if the rocker arms can be 'twisted' on the shafts (turned so the rocker arm is not 90 degrees / perpindicular to the shaft), there's a good chance the rocker shafts and/or rocker arms are worn. This will cause a tapping-like sound that won't go away no matter how many times you adjust the valves to spec. Debris in the valve galley area suggests this is what's going on. Repair consists of replacing the rocker shafts and rocker arms which also may require a headgasket if a lot of caution and careful work isn't done while removing the head bolts and rocker shafts.
__________________
Old 11-07-2009, 07:54 PM   #9 (permalink)
Thanks for the info, I was wondering about the springs between the rockets not the valve springs, what are they there for?
__________________
Old 11-08-2009, 12:50 AM   #10 (permalink)
the springs on the rocker shafts are there to help keep the rocker arms located over the cam and valves. they allow some left/right without letting the rocker arms slide too far.
__________________
Tags
2006, 4runner, adjust, adjusting, adjustment, arms, check, cold, knock, knocking, loose, rocker, taco, toyota, truck, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
