v6 low compression mechanic says I need new motor. HELP
My mechanic said the previous owner had used a sealant in the radiator and now the compression is low, he says I'm going to need a new engine, I'm not the most mechanically inclined and hes quoting me at 3800$ for parts and labor. Does any of this sound right?
It's a 3.0 3vz and the mechanic said the last guy used a sealant in the radiator and that the compression is bad is some cylinder (he a trusted mechanic) so he says I need to replace the engine. How long do you think this engine will last? Im very short on cash atm so idk
prob not long, if you need a replacement dont do the 3800, either buy a replacement motor from a junk yard and swap it yourself (if you can) or send it to wabbit and do a 3.4 swap, better motor, better performance, better mpgs
https://www.yotatech.com/forums/f160/
montanatruck
02-26-2017 07:07 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
