V6 Caliper upgrade on IFS
I was wondering if anyone knew if I could swap my V6 calipers and LC rotors over from my solid axle to my IFS truck. It has the 4cyl calipers. Will I be able to run my stock aluminum wheels?
The calipers will swap no problem, you will probably have to trim the dust shields a little as the V6 calipers are a bit larger than the 4cyl ones. I'm not sure about the landcruiser rotors, the are not the same part # as the ifs v6 rotors, so you will probably have to buy new rotors.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Toys4parts
09-26-2015 01:56 PM
