| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Urgent: My yota Back fires
__________________
89' 2wd Toyota Pickup - 3vz-e, Custom Cold Air Intake, Flowmaster Exhaust, Lowered Suspension, Custom Rims, Black Paint Job, Extensive Sound System to find out more Click here....http://www.cardomain.com/ride/437849/6 Last edited by shoes138; 08-13-2007 at 10:21 PM. |
#2 (permalink) |
help me please.......
__________________
89' 2wd Toyota Pickup - 3vz-e, Custom Cold Air Intake, Flowmaster Exhaust, Lowered Suspension, Custom Rims, Black Paint Job, Extensive Sound System to find out more Click here....http://www.cardomain.com/ride/437849/6 |
#3 (permalink) |
i don't know what you did, but i've been trying to get my 3.4 v6 to backfire for weeks now...lucky bastard...
sounds like time for a tune-up. including timing, fluids, and pressure checks. I guess thats the best place to start. |
#4 (permalink) |
Backfire
Personally I would change out the distributor car and rotor. If that doesn't help, check the timing belt position.
__________________
1994 4Runner 4x4 116k Miles on Chassis, New 3VZE Engine, Manik Brushguard, BF Goodrich All Terrain/TA's 31 x 10.50 x R15LT "Baja Champions" |
#5 (permalink) |
do you run without an air filter? My friend did that and after a while he started having problems similar to that, but I don't know if that is a problem...
__________________
92' Pickup 22RE 4X4 It's all about love, really. |
#6 (permalink) |
HEAD GASKET! Water getting to the plugs, overheating. Coolant causing a code at the O2 sensor. Classic.
#7 (permalink) |
Well if this isnt enough to completely confuse you. Nine times outta ten a backfire is caused by a vaccum issue.
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, Cobra NWWXST CB W/ K40, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V plugin. |
#8 (permalink) |
damn i hope it not a headgasket, but im running witout n air filter n i had my timing done at 175k n im at 215k n that when i had everything done. Ive recently changed dizzy cap,
__________________
#9 (permalink) |
My thought if your air filter is off and just running through the tube, then a lot of moisture could be the problem...
__________________
#11 (permalink) |
thanks everyone problem solved, i just need to changed the spark plugs! tomm im gonna check the timing. Im about to put an airfilter back on but theres hard no dust or dirt that get behind the wheel well.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Back in a Yota | Avsguy33 | Introductions & New Arrivals | 5 | 08-03-2007 10:01 PM |
| Teen fires AK-47 in school | Buck01 | Off Topic Talk | 37 | 10-13-2006 02:21 PM |
| Texas Grass Fires | TxDox21 | Off Topic Talk | 5 | 01-16-2006 09:49 PM |
| Ford document shows millions of vehicles may be at risk for fires | dsm59 | Off Topic Talk | 7 | 06-18-2005 12:32 AM |
