Upgrade Ignition??
Performance ignitions are needed on performance motors.
If your putting a performance ignition on a 22r/e without making other mods youre wasting your time and $$$.
I have minimal performance mods to my 22re and still use the OEM coil,it works just fine.
A upgraded ignition will give you a little more oomph. I had a Jacobs setup on mine for a while but went back to stock after 2 of them died on me, just wasn't worth the hassle for the minimal gains.
All I have is the engnbldr cam and a 2" cat back exhaust. The plan is to through a header and freer flowing cat on after taxes come back. Is that enough to warrant the upgrade or not?
You can do it if you want to, but even with the cam and exhaust it still really wouldn`t be worth it. If you had a ported and polished head with over sized valves, cam and exhaust, then it would definatly be worth doing.
i had a msd blaster ss coil on my truck, and i really didn't tell a difference. so its not worth it unless you have big power gains like a turbo or a stroker kit.
kawazx636
10-06-2021 03:03 PM
4runnerFireman
09-29-2015 06:24 AM
