up and down idle
up and down idle
I did search and found alot of good info but nothing to silve my problem idles up and down and doesnt quit if break is pressed. check whole intake for vacuum leak and none re did the vacuum hoses. idle screw doesnt change it at all. only thing I havent check is egr. I did put vacuum on the top hose coming off egr and it barely made the motor re act also sounds like ill need a timing chain soon.
any info is great thanks
Staff
Dont know which motor you have, I looked on your info site and didnt see it. If it is the 22re and you are suspecting the EGR, alot of the ports on the plenum are most likely plugged. On the first post of my thread, you can find where I put some info on cleaning your EGR . Check for leaks on all air hoses is about the only other suggestions I could make for now.
Staff
The Plenum is a actually what says EFI on it. The intake is the piece that connects the Plenum to head.
Are you getting any codes or a check engine light?
If you check on my 2nd page and on post #43 is on the EGR.
thanks and sorry for being a retard im new to toyotas my plenoum was gunkd bad with sludge i attempted to clean it a little but gave up should I take it back off nd I checked the vacuum abot 3 times it all has to be correct
Staff
You are not retard. It will be gunked up bad if it hasnt been worked on. If you are confident in your mechanical abilities. I would suggest takingit off and taking it to a carwash.
You can clean it on the truck. It may not be the EGR, Im not a pro on these, but usually can eventually get it. You having a Check engine light? I can show you how to pull the codes. What year you have?
Staff
If you are getting a check engine light, take a paper clip or something simaliar and jump TE1 and E1. If it is 87 and up. Yo do the same thing on and 86 and down but the test port is on the drivers side and Im not sure about it. Just what I have been told.
Shut the key off and jump the ports. Then turn on but dont need to go to start position. It will be on Passenger side and turn the key on and count the blinks. For example 71 will have 7 blinks and a pause and 1 blink.
Staff
So a code 51 is legit? I didnt see it in my Haynes. I will make a note of it in there.
Another one I have found not listed in Haynes is a code 27, which is a California O2 Sensor. I think it is the one behind the Catalytic converter. I have a Cali truck and learned the hard way.
Staff
I need to break down and get me a Field Service Manual. I have down loaded on before and just cant get around in it. Haynes doesnt even mention an IACV or I havent found it. Im checking in the emissions chapter and looked in the Index of the manual.
I remeber it saying something about a switch control sensor or something I think my tps is out of adjustment the wires get all the right volts but the tps is actong weird I think ima buy a new tb for 20 see how that works also I can adjust it one way and it will idle high as hell the other way majes it idle like it is up and down
make sure the TB is the correct one, IIRC there was 2 maybe even 3 different TPS's in the 22re truck. but I could be wrong.
89452 SENSOR, THROTTLE POSITION (FOR E.F.I.)
Replaced by: **452-20050 **452-28030 1985.08-1987.08 RN55, 6#, 75.. EFI, TBO 1
Replaced by: **452-20050 **452-28030 1987.08-1989.03 RN5#, 6#, 7#, VZN6#.. EFI, TBO
**452-14050 1989.03-1989.08 RN10#, 110, 13#, VZN10#, 110, 13#
**452-12040 1990.08-1993.08 RN10#, 110, 13#, VZN10#, 110, 13# 1
**452-12040 1992.02-1994.09 RN101, 110, VZN100, 110 1
**452-22090 1994.09-1995.01 RN101, 110 1
I do believe it was the right one as ot didnt start acting this way untill I took the intake off and attempted to clean it I I just going to clean it tomorrow and see where I get. I really dont understand it. guess ill get it one day but I mean it can be but so much wrong
Blamalam
03-12-2022 07:34 AM
noosh
08-21-2015 03:49 AM
