Unplugging the TPS in my 92 22re
Old 07-16-2010, 08:46 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
Ok, I seem to think I am having some TPS issues.
What would happen if I just unplug the thing? I know that it calibrates fuel to what ever specific throttle location you are at but if I unplug it what should happen other than the idle going up a lil bit?
Old 07-16-2010, 09:11 AM
RustBucket's Avatar
Try it. I think that it will run badly if at all.
They are pretty easy to test with an ohmmeter and can be easy to find at pull-a-part -- some older Camrys used the same part I think.
Old 07-16-2010, 09:13 AM
4Crawler's Avatar
It will run on open loop mode w/o the TPS. Basically ignores throttle position and goes by air flow meter readings only. Will also throw a TPS code or two.
Ok, I just wandered if it would eliminate the lack of power I seem to have going up slight inclines.
Gone Fission
01-12-2023 10:34 AM
Blamalam
03-12-2022 07:34 AM
Sidherish
08-03-2015 07:17 PM
Gone Fission
07-31-2015 03:58 AM
Cbr954ryder
07-25-2015 06:32 PM
Quick Reply: Unplugging the TPS in my 92 22re
