uh oh! truk died and wont start again
Old 06-11-2011, 07:23 PM
hunter07's Avatar
sitting at a stop light on way home last nite, truk running fine and out of the blue no warning at all my truk dies. just like i shut the key off, tried starting again with no luck. engine turns over but seems slower than usual and sounds odd. checked the oil and it is fine. im kinda wondering if the timing chain broke or skipped a tooth or two. Is there any way to check for this and what other possibilities should i look at?
Thanks
Old 06-11-2011, 08:03 PM
DeadYoder's Avatar
Exclamation 22re turning over slow
I have the exact problem with mine. Turns over real slow. Thought it was the starter and replaced it. nothing changed... bought a new battery... still the same. checked valve lash, removed all 4 spark plugs and it turned over crazy. tried pull starting, and nothing. tried 1st, 2nd, 3rd, and 4th gear.
Old 06-12-2011, 12:42 AM
wyoming9's Avatar
Smile
To check the timing chain pull the valve cover look down in front of the cam gear with a flash light you should be able to see if something is wrong
Charecter1
11-06-2023 10:08 AM
sandyota
02-04-2021 11:16 AM
Colington
03-08-2020 09:51 AM
Doug4320
03-24-2018 10:11 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: uh oh! truk died and wont start again
