U_Joint problems?
Old 08-30-2009, 06:51 PM
Goathead666's Avatar
U_Joint problems?
How can you tell if the u-joints are going bad in your truck? I have an '88 yota pickup 3.0 and 5 speed 4x4. When shifting it feels like there is a bit of lash in the drivetrain.... Also on take off in 1st and 2nd gear there seems to be a slight driveline vibration, goes away as the torque decreases and truck is up to speed.
Just looking for some ideas....
Thanks Rick
Old 08-31-2009, 08:05 AM
bump, nobody????
Old 08-31-2009, 08:08 AM
874runnersr5's Avatar
just go under the truck, drop one side of the d shaft, and rotate it and check if it has alot of play
SubiKing
08-21-2021 03:57 AM
theking11863
03-19-2016 09:36 PM
Logz808
07-26-2015 07:09 AM
Jonny246
07-24-2015 12:37 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: U_Joint problems?
