u joint
u joint
i know that you want me to search but im kinda in a hurry and need an answer i want to know if the u joints on my 89 pickup 4wd are press fitted or can i change them myself.. if you would like to tell me how to change them or give me a link on more info id be glad to check it out thanks
This is the 3rd result i got when i typed "How to change u joints" on google.
http://www.pirate4x4.com/tech/ujoint_install/
I have changed no doubt hundreds of u-joints and the ones on the Toyotas seem to me to be a major pain .
Because the Yokes and the drive shaft ears are not flat . I had thought of having a special block made up to use with the press to allow the parts to be pressed in a straighter line.
The problem I keep having is the caps keep shifting off the vertical just enough to start digging into the side of the flange. I have tried shims of different size just more to try and keep lined up
At this point I am thinking $200.00 for a new drive shaft is not that expensive . In the morning I am calling the Toyota dealer to see if the Special Service tool for this can still be had .
HEll they are easy to remove a BFHammer and a decent size punch or drift has worked for me when removing them...Then use a good bench vise to reinstall the new ones I've done this at least 12 times in the different Toyota's that I've owned
kawazx636
10-06-2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
