U BOLTS with SHOCK MOUNT
hi i have a 1980 toyota 4wd and my rear stock u bolts, with the shock mounts attached, are threaded for a 14mm bolt. this is original to my truck. i am wondering what the size is for 86-95 rear axles. what is the size of the rear shock mount bolt? is it also 14mm?
also, what is the bolt size for the front lower shock mount of the 86-95? the upper mount is a stem so that's no problem.
i need to know because i am trying to get 5100 bilstein shocks in stock lengths to use on my truck. they only make 5100 lifted shocks but the 86-95 shocks are a little shorter and i wanted to use those.
Blamalam
03-12-2022 07:34 AM
terminator
07-27-2015 07:13 PM
whereAreMyPants
07-22-2015 03:32 AM
jon.r
07-11-2015 03:34 PM
