turn signal comes on when brakes are pressed
Old 01-04-2013, 04:01 PM
laskt9's Avatar
1987 pickup. when I have the lights on my right tail light is lit up by my left is not (could be a dead bulb haven't checked)
the cluster lights come on and the right turn signal arrow will glow dimly.
when I press the brakes the turn signal arrow will light up as if the turn signal is on solid. also the right tail light will go out and the right turn signal comes on solid
also when I turn the turn signal on sometimes it flashes normal sometimes not.
I imagine it is a ground issue but I'm not sure where they ground at
Old 01-04-2013, 04:11 PM
slow-mo's Avatar
I'd recommend an immediate exorcism.
Other than that, you'll need to get the wiring diagram for your year to start tracing down the wires in those faulty circuits. It will also show you were the ground points are as well.
Old 01-04-2013, 04:13 PM
laskt9's Avatar
I was planning on getting it from work today but was too busy with other cars. just seeing if anyone else has had this issue.
Old 01-04-2013, 04:20 PM
scope103's Avatar
Yes, most likely a ground condition. Start by taking the taillights apart and just looking; they are in a corrosive environment and can have obvious faults. Next, of course, you will be using a multimeter.
https://www.yotatech.com/forums/f116...lights-261959/
INFINITY's Avatar
ground gremlin
Old 01-04-2013, 04:23 PM
slow-mo's Avatar
You may have a bad instrument cluster that's causing the issue.
You'll have to give it some time for others to chime in.
The best thing to do is to get the Toyota wiring diagram to be able to diagnose stuff like this.
Old 01-04-2013, 05:01 PM
snap-on's Avatar
you have a trailer hitch with trailer wiring hookup?
toyota uses seperate turn signals and brake lights so you have to get a converter to run both together for the trailer.
bad converter or connections at it. Check grounds like others have said.
Old 01-04-2013, 05:19 PM
laskt9's Avatar
I've heard of the trailer wiring issue. ill bring home my dmm and check the wires tomorrow. its cold out and I have a couple other Toyotas I can drive so its not a high priority to fix
Old 01-06-2013, 09:54 AM
laskt9's Avatar
still cold out so haven't looked too hard but apparently the person who had it before me wired lights up under the truck into the harness under the bed. I'm betting that's part of the problem. also will need to cut and weld part of the frame as it is rusty
Old 01-06-2013, 10:06 AM
XtraSlow_XtraCab's Avatar
x2 with Snap-Ons suggestion but it sounds like you're on a good track with the rinky-dink wiring underneath.
Old 01-11-2013, 06:18 PM
laskt9's Avatar
removed the wiring. no change. the bulb sockets in the tail light are very corroded. anyone have a fsm for an 87 still have no luck finding a good wiring diagram. need to know where the ground is
Old 01-11-2013, 09:16 PM
scope103's Avatar
I can't tell you "where" the ground is on your truck, but you've only got so many possibilities. Start by putting a meter on each wire going to the socket, and have someone work the lights/brakes/turn signals.
MOST likely you have an open ground; the ground wire to the socket is not connecting through to the bulb. When you press on the brake the brake light has no ground return, so it returns through the other filament (the turn signal) and you get your problem.
Old 01-11-2013, 11:53 PM
wyoming9's Avatar
Red face
:jessica: the problem i would bet is right in your tail light sockets .
The tail lights and turn signal ground in the sockets in the mid or late eighties trucks they change when I am not sure. to separate ground wire for each socket .
Clean your sockets Or replace the complete light assembly
If you didn`t know the White wire black stripe is your ground wire there are a few ground points for the turn signals and tail lights.
tail light right fender.
turn signals right and left rear side panels left kick panel right fender
look for the white/black stripe wires screwed into the sheet metal :jessica:
Old 01-12-2013, 06:44 AM
YotaWoRx's Avatar
Ditto. Clean the sockets and replace all the bulbs in the tail lights.
Old 01-12-2013, 07:29 PM
laskt9's Avatar
jumped ground to black white wires coming out of sockets and it works as it should. will spend tomorrow following wire up the truck looking for where it goes to the frame I guess
Old 01-13-2013, 03:18 AM
Pat8942's Avatar
Why not just clip the wire coming from the socket and put a ring terminal on it and ground it in a convenient location, a ground is a ground, why bother tracing a wire if you don't have to.
Old 01-13-2013, 05:22 AM
stock87's Avatar
Check the tail bulb too to see if one of the filaments has drooped onto the other. I've seen systems back feed to the dash lights if that happens.
Old 01-13-2013, 10:26 PM
Green 88's Avatar
I just fixed this on my '88 a couple weeks ago. It's a bad ground at the tail kight housings themselves. It could be a poor connection at one of the rivets that hold the wire to the socket, or corrosion inside the socket itself, or (least likely) a broken wire inside the harness. The reason it backfeeds through the blinker is because the tail light housing is metal and it is mounted to the body with plastic snap in nuts so it goes to the only ground it can find (through the blinker bulb fillimint).
On my truck the rivets had poor connections on the one of the tail lights. I cleaned up the rivets and outside of the socket with a bench mounted wire wheel and soldered it with a little butane Blazer torch and electrical solder with flux in it. The other tail light had severely corroded sockets. A tiny wire brush on a Dremmel cleaned it up and dielectric grease sealed it up (hopefully).
Old 01-15-2013, 08:17 PM
scope103's Avatar
Just be careful with this. On my '94, the bed is electrically insulated (by the shock mounts) from the battery ground. So connecting a ring terminal to the nearest piece of sheet metal won't work for me. I had to "steal" a ground from a known-good ground wire to the rear light assembly.
glowz825
01-25-2022 09:28 AM
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
CanRunner
07-20-2015 01:29 PM
Sandman
07-14-2015 12:36 PM
Quick Reply: turn signal comes on when brakes are pressed
