turbo motor - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-20-2008, 01:20 PM   #1 (permalink)
weaselman's Avatar
Send a message via AIM to weaselman Send a message via MSN to weaselman Send a message via Yahoo to weaselman
Exclamation turbo motor
what do you guys think would happen if i took the turbo off of an 87 22re turbo 4runner and put it on an 86 22re non turbo 4runner. without doing anything much else...
__________________
86 4Runner, 2" Body Lift
weaselman is offline
Old 05-20-2008, 01:31 PM   #2 (permalink)
camo31"10.50"'s Avatar
im not sure you would see much of an improvement....but if you swaped the heads...pistons...new cam...intercooler...allllll that...u would see probably close to 150hp
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 05-20-2008, 01:32 PM   #3 (permalink)
gilby4runner's Avatar
Send a message via MSN to gilby4runner
I believe there would be to much compression for that set up. I know the turbos run a lower compression. Also wouldnt it run lean?
__________________
2002 Sport- (Sporticus) OME 881 / 906 combo, Full Synthetics, 265/75/16 Geolander AT II's,
Brembo / Hawk combo,and a cool car seat for the future wheeler!
Quote:
Originally Posted by UKMyers View Post
What a disappointing thread. Great job bragging about being stupid.
gilby4runner is offline
Old 05-20-2008, 01:39 PM   #4 (permalink)
iamsuperbleeder's Avatar
Send a message via MSN to iamsuperbleeder Send a message via Yahoo to iamsuperbleeder
Yeah, you can't just slap a turbo on a non-turbo setup long block and call it a day. Hey, it may fire up and run, but it won't run very well, not to mention it wont run very long.
iamsuperbleeder is offline
Old 05-20-2008, 01:49 PM   #5 (permalink)
cutboggers's Avatar
It would work if you swapped the injectors(maybe injection) also. Like above though your comp could be too high, but i am not sure. I know you can buy a turbo aftermarket bad boy for your stock 86 so i don't see a problem with compression. prob just create a lot of boost out of a low boost turbo.
__________________
Heavy right foot, quick left foot!
faster than you
cutboggers is offline
Old 05-20-2008, 01:49 PM   #6 (permalink)
you will also have to drill and tap the block for the turbo set up....(oil lines)
__________________
Old 05-20-2008, 01:56 PM   #7 (permalink)
cutboggers's Avatar
__________________
faster than you
Old 05-20-2008, 06:18 PM   #8 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
oil lines are the easy part run a tree on the oil presure sencer and drill a hole in the pan done but as far as comp youll be fine think of the honda girls that do it all the time but fuel is going to be your brick wall you cant use a
SAFC on our trucks trust me i've tried many times but if theres away then you can use all the stock parts!!!!!! EVERYTHING from this doner truck
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 05-20-2008, 06:24 PM   #9 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
keep the boost at a modest level and you will have some fun. Stock turbo engines are only 130 something power...so you won't feel much of a difference.
__________________
Obama is an acronym.
OBAMA = One Big Ass Mistake, America
Hayes is offline
Old 05-20-2008, 08:15 PM   #10 (permalink)
Send a message via AIM to dcg9381
You might be able to bolt it up, keep it under 3-4 psi and see it live for a while. If you go lean, it's going to make a big mess.
You don't need to drill and tap the block for oil lines. There are other ways to do it.
With a 9.4:1 compression motor and a turbo, I made (flywheel, not rear wheel): 169 hp, 244 ft/lbs torque. That's tuned - not going lean, and 93+ octane fuel.
Beyond 10psi I had real trouble getting any additional power.
E85 helps a bit, but at the cost of MPG.
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 05-20-2008, 08:16 PM   #11 (permalink)
scuba's Avatar
stock turbo was 150 i believe
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 05-20-2008, 08:26 PM   #12 (permalink)
Hayes's Avatar
135 horsies
__________________
Hayes is offline
Old 05-21-2008, 08:35 PM   #13 (permalink)
weaselman's Avatar
awsome. thanx for all of the input guys i appreciate it.
maybe working on my truck will help me forget about all my problems. ugh.
__________________
Old 05-21-2008, 08:39 PM   #14 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
yes...
... sigh ...
I find myself ...
and ... my problems find me too ...
... somewhere between ...
me ...
... and my truck ....
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Tags
22ret, safc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Complete 1986 22re Turbo Motor gravy The Classifieds GraveYard 4 06-03-2008 03:43 AM
turbo motor dcg9381 86-95 Trucks & 4Runners 11 10-17-2006 12:53 PM
3.4L 5VZ-FE twin turbo VIDEO (4runner motor) node Off Topic Talk 24 11-27-2005 01:09 PM
is this a Twin turbo or a NA motor? shazaam Off Topic Talk 17 11-04-2005 02:38 PM
2009 InternetBrands, Inc.
