Truck won't start, not getting gas
Old 11-07-2007, 07:47 AM
Tylerars24's Avatar
Hey, Im having an issue with my pickup.
It wont start. It turns over, all the relays that i can find seem to be clicking(EFI, main, etc.) The fuses are good, corroded, but are conductive.
EDIT:
It was running fine last night. The fuel level sender does not work, but I can tell when it is getting low because the less fuel it has in the tank the more it does this thing... ...It will bog out extremely bad when accelerating as if the fuel flow were restricted, but when it has 1/2+ tank it has no problem.
I took the banjo bolt out of the CS injector and there is no fuel pressure at all. I had someone else try to start it and nothing, not even a drop.
I am currently thinking it is the fuel pump, but before I go and spend 130 or w/e on a new one, I thought I'd ask here.
BTW, this is my DD therefore fairly urgent.
Old 11-07-2007, 07:50 AM
MSR
MSR's Avatar
on the 88 the circuit opening relay is above the ecm in the right side kick panel. We replace them quite often.
Old 11-07-2007, 07:54 AM
MSR
MSR's Avatar
check for power at the tank but it sounds like you need to drop the tank and see if there is anything that can explain the half tank thing.
Old 11-07-2007, 08:02 AM
Tylerars24's Avatar
The big relay behind the speaker on the PS?
It clicks clearly, is there a different way to test this relay?
Old 11-07-2007, 09:00 AM
MSR
MSR's Avatar
when cranking engine or when the air flow meter is open the blue wire coming out of the relay should have battery voltage also when the key is on the large black wire should have batt voltage. But in the end you still are going to need to check at the tank
Old 11-07-2007, 11:30 AM
Tylerars24's Avatar
ok,
when I have the key in the "on" position both are 0.00v from them to a ground.
When cranking, the blue is like .14v and the black is 10.3v
any idea?
Old 11-07-2007, 12:58 PM
Tylerars24's Avatar
anyone?
Old 11-07-2007, 03:33 PM
MSR
MSR's Avatar
the blue wire is the one that goes to the fuel pump sounds like you need a relay
Old 11-07-2007, 04:14 PM
Tylerars24's Avatar
thank you VERY much.
I am gonna drop the tank anyway, to try to find the cause of the bogging. Also, my fuel level sender is crap.
Old 11-07-2007, 09:45 PM
Shoua's Avatar
Is it possible that your fuel filter is totally clogged?
Old 11-09-2007, 09:08 AM
Tylerars24's Avatar
Well I replaced the Filter like a month ago; it is possible, but I doubt it.
IP have dropped my tank, and tried to hook the pump directly to the battery for brief periods, it spins, but I have no idea whether it is to spec or not.
Is the fuel pump basically it works or doesnt or can it work, just no well?
Also, I grabbed a COR from a 2wd truck, put it in and the pump didn't work, but it does have a different part number, but the same housing.
zd92655
03-06-2022 12:58 PM
Crazychris1871
06-27-2016 10:38 AM
newzingo
06-24-2015 01:50 PM
Corey
06-10-2002 04:23 AM
Quick Reply: Truck won't start, not getting gas
