Truck wont start, and its not the battery Ideas????
Old 06-15-2007, 08:54 AM
Myron's Avatar
So last night i went to start up my truck and it didn't want to start. Had the battery checked and its fine. I read in the repair manual that i should check the starter relay, but cant seem to find it.
I got a feeling that its the starter. How do i check that
Any help or ideas will be great
Thanks
Old 06-15-2007, 08:57 AM
dijlop's Avatar
just replaced a starter in a friends car. a rebuilt one costs a bit of a hundred. blah. im not sure how to test it though. might be able to find some sort of shop or garage offering free testing? know any mechanics with cool tools/machines? thats where id go first.
Old 06-15-2007, 08:58 AM
rdlsz24's Avatar
What is it doing when you try to start it? Cranking fast, slow, or not at all?
Rob
Old 06-15-2007, 08:59 AM
WFO
WFO's Avatar
Hit the starter with a hammer, screwdriver, anything hard.
Then try to start it. Might have to try a couple times.
If that makes it start... its your starter.
Old 06-15-2007, 09:22 AM
engineerjoe's Avatar
Rob
X2
proper diagnosis is the first step. thell us what it's doing and we'll tell you what to fix.
Old 06-15-2007, 09:43 AM
harpen123's Avatar
if its not clicking check the wires to it then try the hammer thing. its really not that bad to change just 2 bolts 2 wires and lining it up
Old 06-15-2007, 11:20 AM
dcg9381's Avatar
How do your battery cables look? How about your grounds.
Starter click at all?
Old 06-15-2007, 02:18 PM
Myron's Avatar
Everything looks good, cable wise,
All i hear is a click under the passenger side kick panel,
then i hear like the wining sounds....something like the fuel pump..and it doesnt turn over doest click..(like when the battery is dead)
I have the repair manual, it shows me how to test it with the volt meter...but i'm not very smart on that side.
thanks for all the ideas, hope this give you a better understanding
thanks
guys
Old 06-15-2007, 02:29 PM
Swansen's Avatar
hmm, well if its not rolling over at all, i would say its the starter.
Old 06-15-2007, 03:02 PM
SEAIRESCUE's Avatar
Yo,
Its the starter if you are hearing the starter relay click. The solenoid is on the starter. You can disassemble the small solenoid and clean up the round contact disc and get some more miles from it. Can also get a solenoid and replace it. But, with its age, get a new starter or rebuilt one.
No charge this time......
Old 06-15-2007, 07:31 PM
notanymore's Avatar
are you sure you are getting good contact from your terminals to your cables? try cleaning them and retightning them on, i had this happen to me before, one night after seeing a movie it wouldnt start, it would just click and nothing else. the connection looked good and tight but it was just a matter of doing that and it worked just fine.
Old 06-15-2007, 08:39 PM
Swansen's Avatar
oh yeah, forgot to add this, if it doesn't roll over at all, but all the lights stay on when the key is turned on, than i would say its the starter, if the all the lights turn off, then i would say make sure the terminals are tight, corrosion free, and the cable are ok to.
Old 06-15-2007, 09:51 PM
imtxn's Avatar
Hey, Over here the parts houses provide free test services if you bring them the starter!! Me
Old 06-17-2007, 07:16 AM
Myron's Avatar
Thanks a lot for you guyz help. It was the starter.
JF9243176
10-08-2017 04:21 AM
bigblue82
10
07-06-2015 08:27 AM
odonekanobe
06-26-2015 02:27 PM
Taz22R
06-21-2015 04:44 PM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: Truck wont start, and its not the battery Ideas????
