Truck wont start?
Truck wont start?
Ok so i have a 87 4runner with the 22re in, Drove fine one day, went out to start the next and wouldnt start. I know i am getting spark because it will run off of starting fluid. Fuel pump turns on and runs. I am getting fuel to the rail and cold start injector. No codes were stored and the TPS and AFM are both working. Any thoughts on something i have missed. I have searched on here and other forums but am still not having any luck. I dont see any loose wires or grounds and the fuses are fine. Thanks
Paul
Paul
I'd change the fuel filter. It's cheap enough. and check to make sure your getting fire to the injectors. Check the plugs on the harness, where they plug into each injector using a noid tester. good luck with it
i will change the filter just because its cheap but i know i have good pressure at the rail. I checked the injector harness with the mulitmeter and i was getting 12v i havent checked with a niode light yet. I just thought it would be strange that they all died at once. To me it seems like a computer problem. Like the ecu dosent see the truck tring to start
http://personal.utulsa.edu/~nathan-b...fsm/index.html
I know this is for a newer rig but I'd still try some of the diagnostics here. I think most of the system would still be the same between the two. Not sure how close though.
Jim
Jim
sorry i have been busy the past few days but no its not fixed. I checked the main efi relay and its fine. If the TPS is out of adjustment will that keep the truck from starting? I am going to check it again just to be safe. Still getting fuel to the rail though.
no the plugs arent wet. I am going to double check the fuses tomorrow with a test light. The injectors have power to them but i dont know if they are firing will check that tomorrow too. I just dont see all 4 of them just going bad. Theres something i have to be missing but dont know what.
well i got it started.The only thing i did was pulled the pump. It was sitting a little sideways in the cradle so i moved and it started right up. Any thoughts oh and it idles high i think no tach but sounds to fast.
