Truck won't go into 4WD - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-21-2007, 01:35 PM   #1
Hey folks,
My 4Runner has recently stopped going into 4WD (hi or low). I've only used it a couple times to help pull my boat out of the water at the launch. But it's never given me problems before.
Now, when I slide the selector into 4WD nothing happens. There used to be a clunk and the 4WD light would illuminate on the dash.
I thought I saw a thread on this a couple months ago, but I can't find it now.
thanks for your help!
mike
intense is offline   Reply With Quote
Old 08-21-2007, 01:38 PM   #2
4Crawler's Avatar
Assuming an automatic differential disconnect (ADD) front end, see below:
http://toyota.off-road.com/toyota/ar....jsp?id=399612
4Crawler is offline   Reply With Quote
Old 08-21-2007, 01:59 PM   #3
Thanks for the link
My truck is a 1990. I think they started using the ADD later, no?
Old 08-21-2007, 04:06 PM   #4
Elvota's Avatar
Do you have to manually lock your hubs? If yes... then no ADD.
What tranny/ transfer case do you have?
If you aren't sure, just tell us which engine and if you have a auto or 5spd.
We'll assume everything is stock in regards to the drivetrain and help you figure it out.
Elvota is offline   Reply With Quote
Old 08-22-2007, 06:53 AM   #5
More details:
1990 4Runner with auto locking hubs, automagic
Also, it's a 3VZE
Everything in the drivetrain is stock....although, I did add an external piggy-back tranny cooler
Old 08-22-2007, 07:11 AM   #6
4Crawler's Avatar
Quote:
Originally Posted by intense View Post
Thanks for the link
No, automatic hubs were only used up through '88/'89:
- http://www.4x4wire.com/toyota/tech/autohub/
Old 08-22-2007, 07:48 AM   #7
Oh...ok
That puts me back at square one..
Old 08-22-2007, 10:44 AM   #8
4Crawler's Avatar
Follow the troubleshooting steps on the first web page I posted a link to. Likely a vacuum line has come off or has been connected wrong. Or lock the ADD actuator in permanently and slap on a set of manual hubs and you won't have to worry about it:
- http://www.4x4wire.com/toyota/tech/add/
1991 truck 3VZE Help with diagnosis (Results of tests) zd92655 86-95 Trucks & 4Runners 3 07-01-2015 06:48 PM
4wd Engagement Help 1993 3.0 5 Speed SR5 Valvoman 86-95 Trucks & 4Runners 3 06-28-2015 03:45 PM
1997 4runner 2wd Automatic to 4wd Manual - some some help TheManOutside 95.5-2004 Tacomas & 96-2002 4Runners 0 06-18-2015 04:32 PM
More coolness from 4WD & SUV mag Corey Off Road Trip Planning, Expeditions, Trips, & Events 0 07-23-2002 08:21 PM
Tags
08, 1985, 2004, 2005, 2006, 4runner, 4wd, fwd, l2, low, t100, toyota, truck, tundra, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
