Truck starts but quits running in 2 seconds. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-02-2009, 01:11 PM   #1 (permalink)
I have checked the fuel pressure from the pump, and that shows 40 psi. I checked the diagnostic code from the check engine light. The code given is "12" (RPM signal) No Ne and G signal to ECU within 2 seconds after starting. Fault area suggested in Haynes manual is distributor circuit, distributor, starter signal circuit or ECU. I checked the pickup coil ohms/resistance and that is within tolerance. The coil has been checked and also swapped out with a new coil. The resistance in the coil is good and the new coil did not help either so the old coil was put back in. Now I am suspecting the igniter on top of the coil but there is no diagnostic approach in the Haynes manual to check it to see if it is bad or good. Any suggestions?
Thank you,
Steven
1988 SR5 22re EFI non turbo
stevenbrick@hotmail.com
Last edited by stevenbrick; 01-07-2009 at 03:02 AM. Reason: clarification on fault suggestion in Haynes manual
stevenbrick is offline
Old 01-02-2009, 01:15 PM   #2 (permalink)
91Toyota's Avatar
year/engine?
__________________
1991 Pickup - STD Cab - 22re - 5spd - 2wd - DD - Cobra CB w/4ft whip - Hella 500ff - 27" swampers - Flowmaster 40 series - Aussie locker
Quote:
Originally Posted by Squeebs View Post
This jerk at best buy parked way to close to my driver door the other day.
So I gave his expo a few good dings with my door and left a nice loogie on his passenger side window.
91Toyota is offline
Old 01-02-2009, 01:31 PM   #3 (permalink)
year/engine
1988 22re fuel injected (2.4L non turbo)
Old 01-02-2009, 01:45 PM   #4 (permalink)
Shawn6string's Avatar
I found that if the mass air flow or air box is not in place that it will do that. The mass air flow has a flapper that sends a signal to the fuel pump, with little info of what you have done I'm not sure.
__________________
88 4runner 3. don't know--- project
88 4runner 4 cyl auto - Bone stock Plus BFG 31/10/50
JACK'EM HIGH CAUSE
FAT CHICKS CAN'T CLIMB
Shawn
Shawn6string is offline
Old 01-02-2009, 01:51 PM   #5 (permalink)
Windsor's Avatar
Sounds like a loose/broken wire between coil and ECU.
__________________
'87 T4R Deluxe, mall crawler
every non-SR5 option installed (sans AT), as well as:
* Cruise Control (dealer installed)
* Michelin LTX A/T2 31s on 1st-gen alloy rims
* SmittyBilt granny step bar
* SR5 Instrument Cluster
Windsor is offline
Old 01-02-2009, 02:04 PM   #6 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
check all the connectors around the ignitor for any condensation or corrosion and also verify the terminals are firmly seated in the plugs.
__________________
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 01-02-2009, 04:59 PM   #7 (permalink)
muddpigg's Avatar
What did you do to truck prior to this condition.
I'll add to what the others said.
Get a test light for your injectors, see if their getting a signal to squirt. Sounds like cold start is starting engine but the other aint squirting. Check ground
muddpigg is online now
Old 01-03-2009, 06:06 AM   #8 (permalink)
Ok, I will get a test light for the injectors. I tried the diagnostic bypass jumper for the MAF but that did not make it run yesterday. The motor will run if I spray starter fluid up the throttle body throat. This tells me I think, that the ignition system is in good shape, but I agree that the fuel injectors are not squirting.
Old 01-03-2009, 07:20 AM   #9 (permalink)
"...diagnostic bypass jumper for the MAF..."? (I think you meant AFM-air flow meter but that's just semantics.) What jumper? Do you mean jumpering the fuel pump terminal in the diagnostic connector to activate the pump? Also, (and you probably know this) you have to have the duct from the throttle body to the AFM connected or it will not turn the fuel pump on.
The code gives you a good idea of what's wrong: the ECU is not getting the signal from the distributor signalling the engine is turning. The ignitor is aware the engine is rotating which is why it will run with starting fluid, but the signal is not being passed to the ECU for some reason. The ECU will not fire the injectors if it doesn't receive that signal and this is why the engine dies after a couple seconds. The cold start injector is supplying enough fuel for the engine to start and the ignitor is firing the plugs. But since the ECU doesn't get the NE signal the injectors are not triggered because the ECU cannot determine the engine rpms, how much fuel to inject and when to fire them.
__________________
Old 01-03-2009, 07:47 AM   #10 (permalink)
"you have to have the duct from the throttle body to the AFM connected or it will not turn the fuel pump on." is correct. The reason I posted that is because I tried to crank mine for a couple of hours before i remembered reading in the manual that the AFM supplied a signal to the fuel pump, or maybe it supplies it to the ECM first. I could shoot gas and ether in there and it would run for a few seconds then cut off. But I knew it would run because I already had it running before hand with the AFM connected. I knew it was something simple. It sounds like a fuel problem, If your pump is pumping fuel it could be injectors but bypassing the MAP or AFM or even trying a known good would not be a bad idea. There again I could be totally off on your problem. Abecedarian seems to be on the right track.
__________________
JACK'EM HIGH CAUSE
Shawn
Old 01-03-2009, 08:06 AM   #11 (permalink)
Also try removing the air filter, if there isn't enough air moving across the AFM to move the flap the pump might not be getting a signal. Try verifing that the pump is pumping fuel and you have the correct fuel pressure at the injectors .
__________________
JACK'EM HIGH CAUSE
Shawn
Old 01-03-2009, 08:20 AM   #12 (permalink)
jsn_stockard's Avatar
Make sure your 02 sensor is getting a good connection. I snagged my 02 wires on a log once and my truck wouldn't run more than a few seconds at a time.
__________________
www.stockardmaintenancesolution.com
Leave the trail a cleaner place than it was before you got there
jsn_stockard is offline
Old 01-03-2009, 10:44 AM   #14 (permalink)
I also agree with AFM stuff; i had my cable just slightly unplugged, and i got the 2 second run as well.
rangerruck is offline
Old 01-06-2009, 02:55 PM   #15 (permalink)
I ohmed out the AFM?
I used my multi-meter to ohm out the AFM. The resistance readings I measured on the AFM tabs were all infinity (an open condition) instead of what my Haynes manual was showing I should measure. I am going to replace the AFM and let you folks know what happens. Thank you for all the great suggestions. I thought MAF stood for Mass Air Flow sensor but I guess I should have said AFM for Air Flow Meter? Sorry for confusion!
Steven
Old 01-06-2009, 04:49 PM   #16 (permalink)
heck with haynes. do this:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
__________________
Old 01-06-2009, 05:10 PM   #17 (permalink)
toyota4x4907's Avatar
Send a message via MSN to toyota4x4907
Quote:
Originally Posted by abecedarian View Post
edit: My eyes were cold. I thought the "drama llama" smiley said good posting.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 |two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler
'88 4runner|22re|5spd|206K miles|Sold
'93 single cab|22re|5spd|150K miles|Sold|
Pro IFS
toyota4x4907 is offline
Old 01-06-2009, 05:16 PM   #18 (permalink)
iamsuperbleeder's Avatar
Send a message via MSN to iamsuperbleeder Send a message via Yahoo to iamsuperbleeder
Quote:
Correct; our Toyota's (well, 22re's and 3.0's anyway) have a mechanical meter, as you have probably already found out, giving it the "Air Flow Meter", or AFM, name. They have a trap door that opens and moves depending out how much air is flowing through. The more air moving through it, the farther it opens. Under that little black lid on the top of the AFM are the electronics that measure how far that trap door's opening, and sends the info to the computer.
The flow through type found on most newer models, most simply called "Mass Air Flow" sensor, or MAF, have just a sencor that sits directly in the flow of air, and measures the amount of passing air that way. It causes less restriction in the air flow, and there's no moving parts so there's less to break.
Ironically though, both are pretty pricy to replace
let us know how it turns out!
iamsuperbleeder is offline
Old 01-06-2009, 06:14 PM   #19 (permalink)
muddpigg's Avatar
You can run around and check a little of this and alittle of that and not get to anywhere. You can even start pulling and replacing parts left and right but never solve the problem. Three things are needed for an engine to run fuel, air, and fire. Now start narrowing it down.
Old 01-06-2009, 06:58 PM   #20 (permalink)
Quote:
well, the AFM uses the moving air going into the engine to keep it supplied with fuel
it's obviously got fire if it runs for a second
aparently, fuel and air are presesnt as well (for a limited time obviously), because as you claimed, an engine just wont run without them; since it does fire up for a couple seconds, then I guess they're there
but the "2 second run" sounds typical of a malfuctioning or disconnected AFM
go unplug yours, I bet it'll do the exact same thing as what he describes
Old 01-06-2009, 07:06 PM   #21 (permalink)
My '88 did that when I first bought it, but I got code 32, instead of 12 like the OP said. All I did was unplug the AFM plug, blow on it and plug it back in. It fired right up. I even bought a $15 multimeter to check everything
__________________
Pro IFS
Old 01-06-2009, 07:11 PM   #23 (permalink)
muddpigg's Avatar
Interesting jest on your part. I bet if you went out to your rig and disconnected the groung attach to the intake manifold it would do the same thing. So if only the cold start injector fires it runs for 2 sec.
So pardon me didn't realise your depth of knowledge on the 22re.
Old 01-06-2009, 07:15 PM   #24 (permalink)
>snip<
I checked the diagnostic code from the check engine light. The code given is "12" (no RPM signal within 2 seconds after starting).
>snip<
Last I checked the AFM doesn't send an RPM signal to the ECU.
__________________
Old 01-06-2009, 07:22 PM   #25 (permalink)
well I haven't had issues with ground wires myself; I'm only speaking on my experiences here
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Truck starts but needs tons of skinny peddle to stay running. Ultramag 86-95 Trucks & 4Runners 2 07-18-2008 10:28 AM
78 FJ40 starts but will not stay running jbrent Early Land Cruisers 7 01-12-2008 11:00 PM
4Runner starts but dies after a few seconds CC_yota 86-95 Trucks & 4Runners 9 09-15-2007 02:05 AM
STARTS AND RUNS for 5 seconds jandk2005 84-85 Trucks & 4Runners 7 03-04-2006 11:34 AM
91 4Runner 22RE Starts but wont stay running. PLEASE HELP! AstroVannin 95.5-2004 Tacomas & 96-2002 4Runners 2 11-27-2005 04:22 PM
2009 InternetBrands, Inc.
