Truck shutting off
Old 02-02-2016, 04:34 PM
Matthews210's Avatar
Truck shutting off
Ok guys I have a1993 pickup 2.4l I have had this problem a couple weeks and don't know what else to do. The truck will drop rpms when I press the clutch to the point where the truck cuts off. I'm not sure what is going on so i have replaced the clutch to see if that was the problem and no change. Please any help would be great.
Old 02-02-2016, 10:37 PM
RAD4Runner's Avatar
Could be something electrical? Inspect clutch pedal assembly, clutch master cylinder mechanism, and clutch slave cylinder mechanism and surroundings for wiring that they may disturb?
How about starting? If pressing clutch kills the engine, are you able to start with clutch pressed?
Old 02-03-2016, 02:45 AM
It starts fine it will idle like normal because the choke is on the rpms drop maybe 200 then once it gets warm is when I have the problem of it cutting off or idling at 400 rpms when the clutch is pressed. I replaced the master cylinder and bought a new slave cylinder also replacing that on Friday.
Old 02-04-2016, 02:45 PM
Is there anything else I should be looking for
Old 02-05-2016, 04:58 AM
Innocent Fool's Avatar
What happens if you keep your foot on the gas while pressing the clutch?
Does it still stall out? Is there any drag? Can you get it into gear?
Old 02-05-2016, 06:27 AM
It will stay running of I press the gas
89Hilux
01-10-2016 09:10 AM
carid
Vendor Advertising
11-27-2015 03:48 AM
moparbay
11-22-2015 09:03 PM
AppalachianOffRoader
11-08-2015 07:32 AM
jhsantacruz63
11-07-2015 07:35 PM
Quick Reply: Truck shutting off
