Truck Shakes when stoping
Old 11-03-2007, 04:57 PM
dcmbsc's Avatar
when i get on the brakes and come to a stop the truck shakes , the hrader i get on the brakes at higher speeds the more it shakes
what is this ?
Old 11-03-2007, 05:01 PM
youngyota88's Avatar
warped rotors get them turned or replace then
Old 11-03-2007, 05:03 PM
CJM
CJM's Avatar
Warped rotors, if it pulls to one side or the other the calipers may be locking as well-check them too.
Old 11-03-2007, 05:16 PM
ozziesironmanoffroad's Avatar
warped rotors, or the last time a brake job was done, they werent turned and machined, so basically yeah, warped rotors. also might want to check the rear drums, they may not be machined correctly or adjusted properly
Old 11-03-2007, 05:21 PM
aaronk's Avatar
Most likely culprit is warped rotors, but I'm dealing with the same issue and new rotors didn't do the trick... I replaced my rotors, pads, and calipers and still have a shake when braking. I couldn't tell if it was coming from the rear before the front brake job, but after the new front brakes it definitely feels like my shaking is coming from the rear. I'm going to do the rear brakes next (new wheel cylinders, shoes, and re-turn the drums) to see if that solves the problem. If that still doesn't do it I'll look in to the u-joints. For what's it's worth, my shaking can not be felt through the steering wheel or brake pedal.
Old 11-03-2007, 06:09 PM
anotherjeff's Avatar
Over torque and/or unequal torque of the lugnuts can cause the rotor to distort. Loosen and retorque your lugnuts.
Out-of-balance tire/wheels can cause harmonic vibrations. Rotate your tire/wheels.
Old 11-03-2007, 11:17 PM
stormin94's Avatar
Out of balance tire, or wheel, but most likely a warped rotor.
mtrdrms
07-17-2015 02:23 PM
MadMax48
07-03-2015 08:26 AM
YotaGreenhorn
06-27-2015 07:00 AM
94hiluxZE
06-22-2015 10:42 AM
LV_4Runner
16
08-05-2002 11:35 AM
Quick Reply: Truck Shakes when stoping
