Truck runs hot and ive replaced everything need help
so the truck runs between normal and 3/4 of the way up the temperature gauge and goes into red after a while.
ive replaced the temperature sensor, the thermostat a new radiator and a new electric fan.
Check the water pump and the timing belt. I was running warm when the timing belt began slipping over the water pump pulley and not turning the WP at peak efficiency.
Is your head gasket in the early stages of going and leaking exhaust gases into the coolant, thus heating the coolant to abnormally high temps?
May be a long shot. But for me it was i tiny little hole in one of the freeze plugs. Replaced it and no more heating issues. Just look for liquid/vapor around that area.
i forgot about the water pump, and ya i think thats what it is, because there is now a knocking grinding noise coming from that area and i think that barings in the pump are out.
Have you bleed the air out of the system? Mine had the same problem, and it took me 4 tries to get all the air out of it. Once I did, my gauge went to 1/2 or lower, depending on driving speeds.
There are several write ups on here - search "burp"
Peteyg39@hotmail.com
06-26-2015 08:15 AM
saphirekosmos
06-22-2015 10:26 AM
