Last edit by: IB Advertising
- Toyota Tacoma SRunner and XRunner Trucks That Turn Corners<br>Important information to help you understand your Tacoma.
truck makes a clunking noise turning right.
even in parking lots when i do a sharp turn the truck clunks when i turn right. when i sometimes turn right to go onto a rd it also clunks not clicks. you guys think its a cv, ball joint
i dont think its the pitman arm cuz it only clunks turnign right, even when i turn onto another street, so thats not a sharp turn of the wheel so it cant be steering stops. in the parking lots then yes its steering stops, but the thing that worries me is that it clunks while im on the road.
Gary96360...
I would check the ball joints & wheel bearings.
Jack one wheel in the air just a few inches, (chuck the rear wheels & use jack stands please)!
grab the wheel with one hand on top pushing and one hand at the bottom pulling repeatedly. check for play, look at the upper & lower ball joints.
You can check the inner & outer tie rods too. grab the sides of the wheel & do the same thing. see if any steering parts are worn.
Repeat at the otherside.
i hope this helps!
Mike
i hope this helps!
Mike
if, while you're turning, there is also any vertical movement (read: bumps) it might be the sway bar. i had that same issue, one side of the sway bar had broken loose and was grinding. i couldn't even see it when someone else was driving and had to take eveything apart to realize what it was.
My steering stops had the plastic caps on them, visually, but still made a noise at full lock.
They wear out in the center. The cap is still there, but the middle is worn through and it is metal on metal. Check that first, easy, cheap fix.
Mike
Mike
my truck makes a noise when i'm turning sharp in a parking lot, or when doing a u-turn. i thought it was the tie rod ends, but who knows, all the suspension on my truck is stock aside from the shocks. i guess i'll find out what it is when it breaks
passenger - "what the hell was that!?!"
me - "i dunno?"
passenger - "....huh, you might want to check that out"
me - "nah"
i removed a sway bar on a fullsize and it leaned much as the yota with a sway bar. ill take it off to see if that caused the problem.
