| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Is this truck lifted?
__________________
88Runner 22RE, <4k miles on new motor; 31x10.5x15; 4.88's; Aussie rear; extended f/r breathers; 1"bore mc/dual booster/V6 front discs; lame Smitty "steps" (random Frankenstein "modifications" compliments of the PO almost totally undone) 05 Prius, Gold package, custom Corolla sun/moon roof, all leather interior (DD) |
#2 (permalink) |
Well if its leaning toward one side in the front, my first thought was previous owner cranked torsion bars unevenly, but there is no lift brackets on that to my knowledge. Looks stock from here
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#3 (permalink) |
Looks stock to me. Lets see a picture of the rear leaf pack and shackle....
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#4 (permalink) |
Thanks. It's actually leaning because that's the side of the parking garage that slopes up/down. It doesn't lean when it's on level ground.
I didn't see any brackets or anything either. My guess is that I just got lucky.
__________________
#5 (permalink) | |
Quote:
Oh, thought you meant on flat ground it is leaning. Looks stock!
__________________
#6 (permalink) |
I'll take pics of the rear tonight when the sun goes down a bit.
__________________
#7 (permalink) |
See:
- http://www.off-road.com/trucks4x4/ar....jsp?id=398514 Most trucks and 4Runners are set at the factory to about 13.5" - 14" from the top of the rim to the fender lip.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#8 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
looks stock to me. it may just be that the 4runner was never used as a truck so the rear isn't sagging much....
__________________
Quote:
Insomnia: it's a way of life.
#9 (permalink) |
other possibilities are that someone:
1) had the rear springs re-arched 2) installed an add-a-leaf kit, load helper springs, or air bag helpers 3) installed air shocks 4) installed new or used rear springs, either stock height or with a slight lift 5) installed longer rear shackles (an approximate 2" rear lift shackle often levels the vehicle out for a mere $40) 6)short lift blocks (unlikely) 7) or, like has been previously mentioned, you just lucky and have a level headed truck. As for the front, I don't see any signs of the typical drop brackets used with the 3-4" suspension lifts, and I see stock control arms. 1) torsion bars could be cranked up (or down) 2) aftermarket torsion bars installed (normally stiffer but do provide some lift) 3) you might have upper ball joint spacers (usually provide 1/4" lift) 4) air shocks That's about all that can add lift to the front of an IFS vehicle. Mind you, listing these items doesn't mean I think your vehicle is actually lifted or has any of these. Basically, any stock height vehicle could have any of these options done. You just never know. If you can provide pictures of the rear springs and rear shackles, it may help determine what you have. |
#10 (permalink) | ||
Quote:
![]() I'd say the front has no crank on the bars: look at the gap between the compression stops and the lower arm, and the arm is almost horizontal.
__________________
#11 (permalink) |
![]() Mine has new springs. It's at the factory height for an 88. |
#12 (permalink) |
looks like a possible body lift
__________________
1994 X-cab SR5 3.oL 5 spd.,33/12.50/15 AT,3inch body lift,3 inch aal,1.5 inch BJ spacers,Skyjacker 7ooo on the corners and steering stab.,K&N CAI,Rhino liner bottom half of truck,some cheapass cb,Pacesetter cat back,1 1/2 inch longer shackles,asian manual hubs,remote fog lights If you can't take it ,DON'T dish it out DON'T worry mommy will buy you a new one SEARCH THIS........... |
#13 (permalink) | |
here's a 4" suspension lift on an 88 with 265/75r16 tires (just over 31" diameter):
![]() yeah, it's my truck. so you can see how much room is between the upper wheel and fender lip with a lift.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| BJ lifted 1988 truck | Blackulua | 86-95 Trucks & 4Runners | 13 | 05-09-2007 08:59 PM |
| pics of my newly lifted truck | Toy-SkiTzo | 86-95 Trucks & 4Runners | 11 | 09-25-2006 06:31 PM |
| Is this truck lifted or not? Trying to decide. | bryanr | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 06-11-2005 10:54 AM |
| Finally got my truck lifted!! | tacopie | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 05-23-2005 12:00 PM |
| Lifted My Other Truck | mark_fit | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 04-07-2004 11:04 AM |
