truck keeps over heating
Old 03-04-2014, 02:45 PM
jrsixsixtysix's Avatar
Angry truck keeps over heating
1991 toyota pick up 3.0 v6 4x4
I stopped driving my truck in October 2013 to avoid it being towed because it didn't have the new tags. when i drained the radiator i noticed that the water came out orange hinting that its rust water. changed out the water pump because it wasnt working and it got a new thermostat as well. but the truck still keeps overheating. can't seem to figure out what the problem is. Any ideas?
Old 03-04-2014, 06:01 PM
Punchy's Avatar
Blown head gasket, Most likely #6 cylinder.
If you do get it fixed you will also need a new O2 sensor, and possibly a new Cat if you live in a smog test state.
Old 03-05-2014, 05:04 AM
isn't a blown head gasket usually followed by a lot of white smoke coming from the exhaust pipe? thats not whats happening in my truck. could it be that i may have to flush out the radiator?
Old 03-05-2014, 05:23 AM
nothingbetter's Avatar
if your coolant came out rusty coloured and it wasn't rusty coloured when you put it in...I would suggest flushing your rad.
Old 03-06-2014, 11:00 AM
oldblue's Avatar
how was the water pump not working? if the impeller isn't broken, its working. if you have an infrared temp gun you can use that to check for a clogged radiator, harbor freight has them for less than 30 bucks i think. usually, you'll find a hot area on the radiator, and a spot much cooler (50 degrees or more) right next to it.
Old 03-06-2014, 03:59 PM
SoCal4Running's Avatar
New radiator and new coolant. Problem... Over
Team420
01-12-2021 04:57 PM
Cesarl74
04-23-2016 06:07 PM
WI Girl
06-25-2015 03:45 AM
AustinTaco
06-21-2015 09:54 AM
bobbybouche
06-18-2015 10:22 AM
Quick Reply: truck keeps over heating
