truck hesitates and back fires 22re - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-18-2008, 09:09 AM   #1 (permalink)
mudtoy1986's Avatar
hey guys just got my engine in after a month and now it hesitates and back fires
im shure people have asked these questions before any sugestions as to where i can get some ideas as to what i did wrong
well the engine i used was a 22r and my truck is a 90 22re have hooked up all sencors and grounds only thing i can think is timing
mudtoy1986 is offline
Old 05-18-2008, 09:22 AM   #2 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
It sounds like you're running lean off idle.
Not 100% sure if this would cause your problem but the 20r is ~2200cc and the 22R/RE is ~2400 cc's. Considering the EFI on the 90 would be programmed to deliver fuel at a rate for the larger engine, there is a large possibility that your problem is there. You would have to at least recalibrate the air-fuel meter for the lesser air-flow requirements of the 20r- probably relieve some of the tension on the spring inside the afm so it opens more easily.
And definitely make sure the timing is set properly.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 05-18-2008, 09:55 AM   #3 (permalink)
mudtoy1986's Avatar
thanks for the info man but i used a 22r not a 20r but ill check the afm to make shure
Old 05-18-2008, 10:14 AM   #4 (permalink)
doh! sorry. check the valve adjustment, vacuum leaks, TPS too just to be sure.
__________________
Old 05-18-2008, 02:46 PM   #5 (permalink)
mudtoy1986's Avatar
ok thanks man i know my tps is bad cause it revs up and down
Old 05-18-2008, 03:09 PM   #6 (permalink)
fluctuating engine speeds does not necessarily mean a bad TPS.
It could be a vacuum leak, O2 sensor, coolant temp sensor...
__________________
Old 05-18-2008, 03:19 PM   #7 (permalink)
mudtoy1986's Avatar
hmm never thought of that ill look in to it
Old 05-18-2008, 03:57 PM   #8 (permalink)
ahickman's Avatar
oscillating engine speeds = air in the coolant line ?
ahickman is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
wont start back fires out carb and exhaust yotasonly Pre 84 Trucks 7 03-20-2008 12:49 PM
22re hesitates after warm up trousermonkey 95.5-2004 Tacomas & 96-2002 4Runners 14 01-02-2008 06:30 PM
Urgent: My yota Back fires shoes138 86-95 Trucks & 4Runners 10 08-15-2007 12:53 AM
Shakes and Hesitates Tempeboy 86-95 Trucks & 4Runners 4 09-12-2006 01:56 AM
22re hesitates engine code 11 dstep012 Maintenance & Repair Archives 0 07-07-2005 01:40 PM
2009 InternetBrands, Inc.
