Truck has to be held into first gear
Old 07-19-2013, 10:17 AM
Birdland's Avatar
Just finished reassembling my 93 22re 2wd truck after a head and timing chain job. When I bought the truck it was not running and this is the first time I've tried to actually drive it. First thing I've noticed is that the truck must be held in 1st gear in order for it to engage unless it makes a horrible grinding noise. I did a little research on the topic.
I'm hoping that the transmission is not bad as the truck only has 98,000 miles on it. My search came up with a possible worn out shifter bushing and seat. If this is the case, this would be an easy and cheap fix but do the symptoms I described sound like this is the problem? Thanks!
Old 07-19-2013, 10:43 AM
Chickenman's Avatar
Does this happen only in first gear or does it happen in second, third, fourth and fifth (if you have fifth) as well?
Old 07-19-2013, 02:16 PM
Birdland's Avatar
No, this only happens in first gear. I figure I should replace the bushing and the seat just to rule it out. What do you think?
Old 07-19-2013, 05:54 PM
Chickenman's Avatar
I think if it was the bushing it would have the same problem in all of the gears, not just first. But I am not sure about the bushing. I know the one on my tranny is all worn out and it shifts just fine.
If you press the clutch pedal and shift does it grind? Or is it as soon as you let go of the stick it starts to grind like it wants to pop out of first?
Old 07-20-2013, 09:37 AM
Birdland's Avatar
So, I checked the shifter bushing and seat this morning and they are both fine. I cleaned them up and put it back together. The truck still pops out of first. I figured the next thing I will do is drain the old transmission fluid and replace it with the proper amount. Hopefully this makes a difference but if not I guess it's time for the transmission to come out.
Old 07-25-2013, 11:38 AM
Birdland's Avatar
Can anyone recommend a transmission rebuild kit for my truck. Also, what model transmissions are in the 2wd Toyota pickups (1993 22re)
zd92655
03-06-2022 12:58 PM
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
ACZR
06-23-2015 07:55 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: Truck has to be held into first gear
