| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Truck dies - igniter and coil?
#2 (permalink) |
sorry, but trying at teh moment to figure out how to get my pic file sizes small enough to post...... I never claimed to be smart!!!!!
#3 (permalink) |
photobucket your pics then post them here
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#4 (permalink) |
Here's my 86.
__________________
1986 22R 4X4 pickup. Currently rebuilding the engine. Last edited by flyingbrass; 11-14-2009 at 12:35 PM. |
#5 (permalink) |
#6 (permalink) |
jeez, that doesn't look good. I know the thing is engineered but it isn't even close. I did a vin# check to make sure of the year when it was purchased and it says 87 though the title says 89. Considering the look of things maybe its a nissan! (joke!)
#7 (permalink) |
those pics show the coil, right? I know its a dumb question but I am still trying to find out what the igniter looks like. According to Haynes it is mounted on the coil with four bolts and its a square metal device.......
#8 (permalink) |
Do you have points in the distributor or the electronic pick-up? If you have points, you won't have an igniter.
__________________
Why do people run the dishwasher and walk the dog? I would love to go look but I'm too busy sorting my random coin flip collection.
#9 (permalink) |
honestly that is what has me confused. According to the information provided in my generic manual ("all vehicles covered in this manual are equipped with EI systems..... 1979-1995") and yet it is obvious to me this is not the case. I do indeed have points/condenser and yet by my vin it is indeed and 87!?!?! what gives here?
#10 (permalink) |
but any tips on troubleshooting and possible causes are still appreciated!!!
#11 (permalink) |
Coil and ignitor on my 87 4Runner.
__________________
1987 4Runner, 22RE, 5 Speed, 2 inch lift, and topless. |
#12 (permalink) |
does anybody know for sure if toyota produced a stock non-EI truck in 87? Also, is it unheard of to convert from EI to conventional ignition?
#13 (permalink) |
check for fuses and loose cracked or frayed wires
#14 (permalink) |
sure, I have all the loose, cracked, and fused wires you could ever want!!!!!! as for fuses....well, let me say again that this thing is "island engineered" to the max, so it's really very hard for me to know what it is actually supposed to look like and which fuses and relays are currently functional or even necessary. Honestly I'm hesitant to mess with anything that isn't blatantly trashed. It seems that every time I touch something that to me looks like it is long past overdue for replacement I open up a whole host of issues (such as WTF did that thing actually do? or the ever present where exactly am I going to get that thing here.) Our parts selection on island is dismal on a good day..... I do know that I have 12.1 volts to the coil (the + terminal), and for some reason get 12.1 volts out of the - terminal that then goes via speaker wire (YEAH!!!) to the carb choke assembly and some other rigged electronic device on the carb. I also know that my wires are fairly new and test good. Most importantly I am sure I get no spark of any kind....... aarrggghhhhhhhhhhh
#15 (permalink) |
is there anyway to test the lead that goes from the coil to the center of the distributor? if so how many volts am I looking at there, as I have only one decent multimeter and don;t want to kill it. Those things are hard to find here too!!!
#16 (permalink) |
Mine is an igniter/coil combination. If you look close, it even says so. It's original. I don't think much changed between 86 and 87.
I don't know what year Toyota stopped using points, but the distributors in 86 didn't have them. Sounds like someone swapped in an earlier motor, or at least hacked in an early ignition system. Since your setup was working before, it must be wired ok to function. You have points, so you also have a condenser. Maybe it conked out when the coil went. I don't know how likely that would be, just guessing. Does your book have any test procedure for it?
__________________
1986 22R 4X4 pickup. Currently rebuilding the engine. |
#17 (permalink) |
sorry, after I looked closely at your pics I did see "coil with igniter" clearly written on it. It is looking like I do indeed have a hack of some type going on here but I am totally not surprised by that. Just wish I could figure out what has been done. I have a Haynes for 79-95 trucks/4runners and it has test procedures only for the EI. But I have lexperience with points based ignitions so correct me if I'm wrong but I should be able to manually compress the points and get a spark there (or at a plug if the rotor is in the right position) if the coil is putting out juice, no?
PS-thank all of you for the help so far. this place is a godsend for me!!!!! |
#18 (permalink) |
Somewhere along the line the current or spark is stopping , stripped frayed melted or otherwise broken wire or part , possible fuse .
Keep us updated and good luck |
#19 (permalink) |
check ground on bottom of coil im just throwing this out there
#20 (permalink) |
So, you have contact 'points' in the distributor, right?
Find an FSM that includes points-type ignition and follow the procedures to adjust them.
__________________
