Trouble with timing
Old 02-25-2011, 04:48 PM
jpoe's Avatar
Trouble with timing
I am able to get the timing close to where it needs to be, but can't quite get there. I positioned at 5 BTDC and inserted the distributor. I attempted to jump E1 and TE1 ( I was told that there should be a noticeable retardation, which there is not) In a thread that I am unable to locate now, I read that there was a ground located behind the fuse box on the passenger side, which I located. There was a ground wire that was cut left dangling there by the PO. Could this be my problem? Where did this ground originate from.
89 22re 4x4 standard cab.
THanks'
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
cyclist231
07-07-2015 12:56 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Trouble with timing
