trouble starting
Old 06-14-2010, 11:48 AM
rebelrunner's Avatar
trouble starting
does anybody elses 3.0 take 10 seconds to start? it will sputter when i crank it and then slowly and weakly it will start. how can i fix this problem?
thanks in advanc
Old 06-14-2010, 04:23 PM
bump
Old 06-15-2010, 07:32 AM
nobody has this problem or can tell me how to fix it?
Old 06-15-2010, 09:09 PM
betelnut's Avatar
Hey from Austin.
My first guess is that the fuel system is losing pressure. There are two terminals on the diagnostic block you can jumper to get the fuel pump to run before the car has started. (Search for it in these forums.) If you jumper it and then it starts immediately, you know you've either got a fuel leak to the outside (which you could smell), or else your fuel pressure regulator is leaking fuel back to the tank. And it's a cheap and easy diagnostic, it'll cost you a paper clip.
Old 06-15-2010, 10:16 PM
bend's Avatar
Yea I would recommend the search button. This topic has been covered quite a few times.
Old 06-16-2010, 03:15 AM
WatsonToyota's Avatar
mine would start every time instantly....you def got somethin goin on.....did you check the turn signal fluid reservoir yet??
Old 06-16-2010, 06:24 AM
thanks betelnut. thats what i thought it was, just wanted some conformation on it.
Old 06-17-2010, 07:27 AM
betelnut's Avatar
Actually just did this yesterday. Jumper the 'FP' (fuel pump) and 'B+' (battery +) together to get the fuel pump to run. You'll be able to hear it quietly buzzing by the rear wheels.
Don't forget to post back with the results!
Old 06-17-2010, 07:53 AM
i havent gotten a chance to try it but when the key is in the on position i hear a click noise from the rear abs and then a couple seconds later i hear the fuel pump running so i think its just kickin in late.
Old 06-17-2010, 06:39 PM
betelnut's Avatar
Prob. not the fuel pump you're hearing, if you mean the car's not running when you hear it. The fuel pump is switched on in the AFM, which needs to be open a minimal amount (i.e. car is running) before the contacts close.
My truck makes a whirring noise from the rear ABS for a moment after turning the ign. on. That's in the front though; fuel pump is in back.
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
Huntingtruckcletus
07-08-2015 05:26 PM
cyclist231
07-07-2015 12:56 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: trouble starting
