Trouble Replacing Front Brake Pads!!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-20-2008, 02:31 PM   #1 (permalink)
I am trying to replace the front brake pads on my 1994 Toyota Pickup. My first problem was getting the calipers off due to rust. I was finally able to get them off with a little PB Blaster and banging on the wrench with a hammer. Now, I cannot get the cylinder in either caliper re-compressed. I was able to get the driver side caliper compressed some, but not enough to get it back on. It took A LOT of effort to turn the c-clamp I was using to compress the cylinder as much as I did, and I cannot compress it any further. In fact, I will have to get a new clamp since I broke the one I was using while trying to compress the cylinder. I don''t remember compressing the calipers ever being this hard on any other vehicle. Is there a trick to Toyota calipers that I am unaware of? I really hope that the calipers are not done for. Any help will be greatly appreciated.
chiggin is offline
Old 11-20-2008, 02:45 PM   #2 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
i taqke it your in the salt belt lol well mine were easy as pie they should just go back in and from the sounds of it you might have a stuck caliper
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 11-20-2008, 02:48 PM   #3 (permalink)
space-junk's Avatar
the calipers tend to get sticky with rust and dirt and such, so you either need to rebuild them or replace them...
do a search to find info on how to rebuild them...
__________________
Trailer Re-Build - Check it out!!!
Quote:
Originally Posted by Junkers88 View Post
From the back of the crowd you hear a slightly slurred Clint..."Hell that ain't nothin'. Give me the damn keys and hold my beer, I'll show you how to kill a Yota."
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III
Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack
space-junk is offline
Old 11-20-2008, 04:09 PM   #4 (permalink)
SR5
SR5's Avatar
x2 i had the same proble when i did mine, if you take i to shucks, give them your old core and they will give you a new about $50 per side
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Old 11-20-2008, 04:09 PM   #5 (permalink)
SR5
SR5's Avatar
also not all shucks have them in stock, so you got to call around
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Old 11-20-2008, 04:29 PM   #6 (permalink)
While it sure sounds like a stuck caliper, before you trade them in you might disconnect them from the brake line and then try to push the caliper in. I had a different make truck where the flex-line clogged inside; you couldn't push the caliper in because the fluid had nowhere to go.
__________________
1994 6cyl 4wd XCab -- all stock
scope103 is offline
Old 11-20-2008, 05:11 PM   #7 (permalink)
Marc's Avatar
Make sure the cover is off the master cylinder.
Also, rent or borrow a proper caliper compression tool.
It works way better than a c-clamp. I think cause it presses evenly.
__________________
'91 4Runner SR5 V6 4X4 Auto, A/C, 4.56, 31x10.5x15 Nokian Vatiiva Tires, Taurus fan (removed)
'90 4Runner SR5 V6 4X4 Auto, A/C, 4.56
V6 power with V8 fuel mileage
I've used Fram oil filters and dino oil in all my stuff for 30 years and never had trouble
I bet MOST people who say "swap in a 3.4" have NEVER changed any engine nevermind converting to a different type
Marc is offline
Old 11-20-2008, 05:19 PM   #8 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
If the caliper is fully removed from the vehicle, lines and all, and the pistons will not compress rather easily- should realistically only take a few pounds of pressure to do get the caliper piston moving, your choices are to either rebuild or replace the caliper.
Personally, I'd rather replace the caliper.
New/rebuilt calipers come with warrantees... rebuild kits do not.
__________________
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 11-20-2008, 06:56 PM   #9 (permalink)
My $0.02:
I've done this job a few times. Aftermarket (rebuilt) calipers are so cheap that I just replace them. At about $30 apiece, I can't justify spending the time it takes to rebuild them (BTW,I did rebuild them the first time).
ddwyer is offline
Old 11-21-2008, 02:59 PM   #10 (permalink)
After a little closer examination, I figured out how to get the cylinder to compress. Originally, I was putting the old brake pad against the cylinder and compressing the c-clamp against that to help distribute the pressure a little more evenly. Right before I started taking the caliper off to replace it, I tried eliminating the use of the brake pad and put the end of the c-clamp down into the cylinder. It compressed with ease. I guess the pad was pushing against something that would not let it go anywhere. I really wish I had figured this out before I put so much effort in, but I am glad I got it. Thanks for the input from everyone.
chiggin is offline
Old 11-21-2008, 07:22 PM   #11 (permalink)
if it gave you resistance with the pad in place... is it going to release from the rotor when you let off the pedal?
...just a thought: it may be 'slow' to compress but you should be able to push the piston in with your fingers. If you need a c-clamp to compress it, I'd still contemplate replacing them.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
replacing calipers rotors and pads.. TROUBLE! bigt 86-95 Trucks & 4Runners 2 06-14-2008 03:43 PM
Problem while replacing brake pads NRM 86-95 Trucks & 4Runners 16 01-16-2006 02:31 PM
Brake Warning Lamp on after replacing front pads ob1jeeper Maintenance & Repair Archives 2 09-12-2005 04:48 AM
replacing brake pads/shoes rotors/drums rearviewmirror 95.5-2004 Tacomas & 96-2002 4Runners 2 12-04-2004 03:51 AM
Replacing brake pads 22Ryota 95.5-2004 Tacomas & 96-2002 4Runners 1 05-15-2004 02:09 PM
2009 InternetBrands, Inc.
