| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
'95 4Runner SR5 running 31x10.5's. Installed the "YELLOW HOSE OF TEXAS MOD" Stripped the running boards and evened out the rear with spring spacers |
#2 (permalink) |
undo the battery and turn the key a few times and plug the battery back up. try that
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
#3 (permalink) |
x2 undo the battery and rub the cables together then hook battery back up Rubbing the cables together should clear all power and inturn clear the codes stored. It will also make your truck relearn your driving style and adjust the computer to it.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. Last edited by olharleyman; 10-09-2007 at 03:35 PM. |
#4 (permalink) |
CEL Code
Maybe you have a bad wire or MAF Sensor and every time you key the thing it is regenerating code , EFI removed for 30 secs should be enough , and battery disconnected for a few minutes as well , may prove worthwhile to try the "Turn on Ign Key" I guess for GP but ahould have cleared
__________________
Guy '91 ExCab Dlx Longbed/3VZE-Fast/Stock 2WD/5spd Manual '95 GMC Jimmy SLS 4WD/4.3L Vortech/Euro Susp and Motor Package/Tow Package F.A.I.T.H. Forsaking All I Trust HIM Matthew 19,20 : 19 I say again unto you,that if two of you shall agree on earth as touching anything they shall ask,it shall be done for them of my Father which is in Heaven 20 For where two or three are gathered in my Name,there Am I in the Midst of them |
#5 (permalink) |
you should remove the efi fuse, not the relay.30 sec should do it unless there is an actual problem.
__________________
my truck new my truck now with TRD wheels and exhaust 93 toyota 3.0 manual trans. jeeps are so cute even barbie has one!!! |
#6 (permalink) |
Ended up touching the battery cables together. Worked fine codes are clear and we'll see if they pop up again. Thanks all. Also the driving dynamics did change a little, barely noticable. Not sure if it was for the better or worse, but different none the less.
__________________
#7 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Bear in mind, sometimes if one is messing the AFM harness a lot...taking it on and off.....the wires/terminals can work themselves loose from the connector and not get a connection when you plug the connector back in. So, if ever in doubt, it's a good thing to check for.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#8 (permalink) | |
Broken Wire
Quote:
__________________
#9 (permalink) |
Do you have a capacitor installed for your stereo?
If so it will store enough charge to keep your ECM memory alive with the battery disconnected for quite some time. Touching the cables together would have discharged it.
__________________
Targetnut don't talk about it, just do it! Precision Import Service '93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate |
#10 (permalink) |
Codes
Well when you reset the ECM it will go into a re-learn mode for a while so the motor running/idling should improve over a bit of time driving , hope your code free !!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| All sorts of trouble codes Please Help! | mrboyertown | 86-95 Trucks & 4Runners | 7 | 10-13-2007 04:51 PM |
| Help with Trouble codes | MRecio | 86-95 Trucks & 4Runners | 5 | 09-28-2007 09:14 PM |
| trouble codes help now what?? | 1987 street toy | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-05-2004 07:58 PM |
| Trouble. Reading Trouble Codes | evilcow | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-02-2004 08:05 PM |
| checking trouble codes | Robinhood150 | Maintenance & Repair Archives | 1 | 06-15-2002 01:58 PM |
