trimming upper control arm
This part of the arm is barely rubbing against the tire. Has anyone taken their grinder and removed the part that is circled with success?
Yes, I ground that lip back a bit on my rig. Not an issue to grind it, that material out at the end is not in the critical loading area for the control arm.
Grind away, and wear safety glasses.
The lip on the end is actually structural...The torsion of the 90 degree lip helps to stop the whole thing twisting under load. You can modify it if you want, people pie cut UCA's, you just have to put the strength back in when your done.
Sonoran Steel has shaved upper A-arms... they take stock 3rd gen runner a-arms and cut them and then weld it up... check it out on their website for a reference
This thread has pictures of an upper control arm cut and welded to clear tires:
https://www.yotatech.com/forums/f116/morph-187544/
1uzRunner
63
11-10-2018 03:58 PM
LotOMiles
09-14-2015 11:45 PM
justdifferentials
09-05-2015 06:52 PM
kirkrunner
07-27-2015 07:59 PM
