trick to rubber shock boot?
Old 06-05-2008, 03:24 PM
notanymore's Avatar
i just got my new rancho rs5000 shocks today and i cant get the rubber boot that came with it on, the rubber just doesnt seem like it can stretch enough to make it, anyone have any tricks they use to get them on?
Old 06-05-2008, 03:31 PM
dbcx's Avatar
All the rancho shocks I had were a pain to get the boots on,not sure wha they have goin on. I just bought some procomp shocks and the boots went right on. Dawn or dish soap will make them slicker if your having the problems i used to have, its been awhile since i fooled with rancho shocks. They always semed to ride rough
Old 06-05-2008, 03:46 PM
pepsibluefloat's Avatar
i used pliers and just had to work them down one side at a time. took about 15 mins per shock and i was warn out after all 4
Old 06-05-2008, 03:50 PM
mt_goat's Avatar
X2, a little soapy water should do the trick.
Old 06-05-2008, 04:17 PM
ozziesironmanoffroad's Avatar
i used WD-40. worked like a charm, but still not as easy as it should be to put on.
Old 06-05-2008, 04:35 PM
Kaleb's Avatar
Don't put them on. Shock boots are ugly as all hell, and when water gets inside it tends to stay inside.
Old 06-08-2008, 05:43 AM
dirtoyboy's Avatar
If the shock is mounted upside down (rod on top) the boot should not be removed....rocks can get in the top of the seal destroying it...
If the shock is mounted right side up (rod on bottom) the boot should be removed because water will sit inside and rust and pit the rod
at least thats my logic behind it....FWIW
choppe777
05-16-2016 08:00 AM
voiddweller
53
02-01-2016 05:46 AM
mistershmi
01-05-2016 11:07 AM
fountain
09-28-2015 03:04 AM
adamk
09-23-2015 03:24 PM
Quick Reply: trick to rubber shock boot?
