Transmission Whining in 3rd & 5th - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-23-2006, 08:42 AM   #1 (permalink)
Newbie to the site here from NE Georgia. I've had 5 '87-88 Toyota 4wds in the past few yrs and this is the 1st one that has done this. Just bought it recently. 1987 Regular cab 4wd with 5 spd tranny. Only has 105K original miles on the truck!! Tranny whines bad in 3rd gear and real bad in 5th gear. Gets louder the faster you go. Doesn't whine until "under a load" going down the road. Shifts fine into these gears and all other gears sound/shift great.
Anyone know what the problem is?
Money is real tight right now but this truck is so nice that I want to get it fixed or find another tranny.
What year 5 spds will fit this truck if I need to find another tranny? A friend has a '93 5spd I can have with only 130K on it. Will it work?
Thanks!
knowjesus is offline
Old 10-23-2006, 09:28 AM   #2 (permalink)
Flash319's Avatar
Your input bearing is going on the trans. I have had 3 go like that. It will get worse and then start popping out of gear. The 93 will work but you will have to cut the floor a bit as the G-56 shifters are about 4inches ahead of the W-56. Not a big deal. You will also have to swap the 2 sensors with the ones from your 87. One is in the trans and the other is in the transfer case. They just screw in the side. Everything else is the same.
Flash319 is offline
Old 10-23-2006, 11:07 AM   #3 (permalink)
rezrunner92's Avatar
If you have a bearing noise in several gears and it seems to disappear in fourth, you most likely have a bad input bearing. Not a big deal to replace but if it were mine I would go ahead and swap it and have the bearings and synchros replaced for a spare tranny.
__________________
1992 4Runner SR5, A340H, 3VZE, Stock suspension, Warn manual hubs, 31" x 15" tires.
1992 Reg Cab P/U, 22RE, 4x4 5spd, work truck.
1992 4Runner SR5, A340H, 3VZE, Running Boards, Sunroof, Roof Rack, Stock Mall Runner 160,000 actual miles, wiped out bottom end, good heads, good transmission and SWEET, paid $800
rezrunner92 is offline
Old 10-23-2006, 06:05 PM   #4 (permalink)
Thanks for the quick replies, anyone else have an idea of what the problem may be?? Just trying to get several opinions before I make a move.
Old 10-23-2006, 09:39 PM   #5 (permalink)
Asha'man's Avatar
Quote:
Mine does that. By input bearing you mean the pilot bearing?
__________________
--Brian
Truck - 1986 4Runner SR5 - 22RE, 5spd, 265K, 3" OME/BJ spacer lift, 33x10.50 BFG AT's, elocker w/ factory controls, 4.88's
Car - 1995 Lexus SC400, red/black, 220K, coilovers, exhaust
Pickup - 1985 Toyota Xtra cab pickup - 2wd, 22R, 5spd, 270K miles, 4Runner buckets, currently two colors
Asha'man is offline
Old 10-24-2006, 06:32 AM   #6 (permalink)
Not the pilot bearing and not the throw out bearing. The input bearing is the one that is in the front of the transmission case with the input shaft sticking through it. There should be a cover over it that the front transmission oil seal is in.
__________________
Old 10-25-2006, 12:02 AM   #7 (permalink)
Asha'man's Avatar
D'oh my bad, I know what you mean now. Hard to replace on these trannies?
__________________
--Brian
Asha'man is offline
Old 10-25-2006, 12:20 AM   #8 (permalink)
Bear80's Avatar
Send a message via AIM to Bear80
3rd and 5th are on the counter shaft. the counter shaft bearings are always first ones to complain. even with relatively low miles, they PO probably ran larger tires on it with out re-gearing.
__________________
1986 Truck - Monster IFS
1997 FZJ80 - Locked, Lifted, Ready
Range Rover Recovery Vehicle
Bear80 is offline
Tags
5th, toyota, trans, truck, whines
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
4Runner Transmission Grinding and Whining EToy 95.5-2004 Tacomas & 96-2002 4Runners 0 12-16-2006 08:03 PM
Ft. Collins-Denver-Mar. 5th & 6th MudMonkey Off Road Trip Planning, Expeditions, Trips, & Events 9 03-03-2005 07:31 PM
Help ! whining/sqqealing noise in 3rd & 5th gears indianrider 95.5-2004 Tacomas & 96-2002 4Runners 2 12-03-2004 07:28 AM
Tachometer & 5th gear ratio snowxninja 95.5-2004 Tacomas & 96-2002 4Runners 5 07-16-2003 10:35 PM
whining in 3rd and 5th tystoy 95.5-2004 Tacomas & 96-2002 4Runners 3 04-22-2003 06:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
