Transmission Too Hot?
What is too hot for an auto transmission? Does anyone know what temp the the stock auto idiot light comes on at? Thanks for the help!
Like an engine, I wouldn't run the oil over 250F for any significant length of time. ATF is mostly the same as a high-detergent 0 or 5 weight oil and will break down if ran at high temps for too long. In general, the ATF temp should run close to the coolant temp, plus maybe 10-20 degrees when under load.
As for when the light comes on, can't say as I don't have that info next to me.
Filter and fluid was changed less than 5000 miles ago. I'm going to add a cooler when I figure out where to put it (my front bumper does not allow for much room, so I'm going to have to mount a fan assisted cooler towards the rear of the vehicle)
shrek99352
08-31-2015 04:16 AM
Dennisx2
08-04-2015 01:26 PM
Poncho0206
07-10-2015 06:21 PM
