Transmission removal tips
Old 05-20-2009, 11:00 AM
tedsch47's Avatar
I have an 87 4Runner. What is the best way to remove the top two bolts on the bell housing. Specifically breaking the torque on the bolts?
Old 05-20-2009, 11:15 AM
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
IDK never done it but you could try unbolting the engine and trans mounts and pulling the trans down to angle the engine up. Might get better access with a cheater bar and long extension.
Old 05-20-2009, 11:20 AM
w.a.r's Avatar
just replaced the engine my 95 4runner last week. the top bolts are not that hard. we used a 20" 3/8 extension with a 17mm swivel socket. then attach a breaker bar and twist.
Old 05-20-2009, 11:34 AM
rdlsz24's Avatar
Extensions!!
Rob
Old 05-20-2009, 11:42 AM
abecedarian's Avatar
One of these:
and a 17mm socket are all you really need.
Old 05-20-2009, 01:55 PM
Flash319's Avatar
Drop the trans/xcase cross member down until you can get at them. Then I use an impact gun and 4 inch extension. You can put the hole gun up there and pow, off they come.
Old 05-20-2009, 02:06 PM
Junkers88's Avatar
I did this a few weeks ago on the 89 runner. What I did was pull the X member out (jack under the tranny) and then lower the tranny/t-case down about 4 inches. It gave me enough room to access the top two bolts through the shifter plate (with the plate and shifters removed). I think it was about 2 feet of extensions and a deep socket with a 3/8 drive ratchet and a small cheater pipe. You can feel your way to the bolts if you're familiar with the location of them.
Put them back in the same way.
Oh and if you don't have a tranny jack then go rent one. That thing saved my bacon, and saving bacon is paramount as we all know.
Old 05-20-2009, 02:29 PM
bxlt's Avatar
I was able to get to mine with 24" extension and a wobbly adapter. Passenger side was almost easy the drivers side was a pita but if you remove the exhaust shield it is a little easier.
I was way to afraid to lower the engine like Junkers did but the tranny jack is a must, or the adapter like I got from the local auto parts store.
Old 05-20-2009, 02:40 PM
NorCrawler's Avatar
Impact gun if you got one!
Old 05-20-2009, 02:59 PM
Jay351's Avatar
x2!!!
tranny jack all the way. Or make an adaptor for your floor jack. Trying to bench press it, or balence it on a floor jack is not fun...
You can also put a bottle jack under the front of the motor and slightly jack it up. We did this for added clearance when we did my clutch..
Old 05-20-2009, 03:04 PM
Just to add to the 'fire'- adding extensions between the bolt and the ratchet or impact or whatever increases the amount of torque required to break the bolt free since the extensions will act exactly like the torsion bars on the front suspension and will absorb some of the torque and twist applied thus requiring more torque than necessary.
My little ratchet above works fine, no extensions on the socket and can break the bolt free with little more than moderate effort... or a 24" cheater.
Old 05-20-2009, 03:15 PM
Justinvd's Avatar
You can always detach the body mount bolts and jack the body up like 3-4 inches(just making sure nothing gets overly tight like lines and wires) but its pretty easy with extensions and a swivel socket and someone to sit in the engine bay and guide/hold your socket on the bolt while your unscrewing it.
Old 05-20-2009, 03:25 PM
w.a.r's Avatar
the first time we did it with a bunch of extensions the impact would not break them loose.
Thats when we got the 20" extension. we didnt have to lower trans or take off the crossmember. you can slide your hand and touch the top bolts through the side. for the drivers side we had the exhaust removed it took us about five minutes
to do all the trans bolts.
Old 05-20-2009, 03:32 PM
iamsuperbleeder's Avatar
after getting an engine torn down to this:
you can reach right around the back of the head and put a ratchet with a swivel-head on it, similar to the one Abe showed; the one I used is like this:
although, the tare-down might be the long process to do so, lol
Old 05-20-2009, 03:47 PM
Flash319's Avatar
Off topic:
jesus, buy a 5 dollar rubber gasket.................
Old 05-20-2009, 03:56 PM
thanks for acknowledging me.
The difference between a straight handled ratchet with swivel head like you used and the one I posted (offset handle with swivel head) is that with mine, when the socket is placed on the head of the bolt, the swivel in the head and bend in the handle puts the grip and pull direction nearly perpindicular to (right angle) and in line with the bolt head, so you are applying torque directly to the bolt head without 'spring' or 'torsional' loss due to extensions: if you drew a line through the grip to the socket, the socket and swivel combined with the bend in the handle put your hand in a place where it's less likely to cause the socket to kick or shift off the head as if you were pulling at an angle to the socket and reduces rounding of the bolt head as well.
It's a little frustrating because the swivel in the head lets the socket move while you're placing it on the bolt, but once you get it on the bolt, as long as you pull straight, there's no problem.
But it's nice to see someone else thinking beyond using extensions and more towards using the right tool for the job.
Old 05-20-2009, 04:04 PM
scope103's Avatar
Originally Posted by abecedarian
One of these:
Not that you need another reason to get one of these, but I think this is also the best tool for removing the exhaust crossover.
Old 05-20-2009, 04:49 PM
Flash319's Avatar
[QUOTE=abecedarian;51144613]thanks for acknowledging me.
QUOTE]
No prob, your the $&it!!!
chuckross1957
06-28-2019 10:19 PM
Dieselmann
02-19-2019 02:57 AM
Team420
12-30-2015 01:31 PM
Tigbucket
07-30-2015 07:29 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Transmission removal tips
