transmission problems
Old 05-19-2007, 03:44 PM
rooney's Avatar
I don't post here too often but i've had some problems with my auto transmission on my 4 cyl 86 runner. I know this may belong in newbie tech but i saw a thread on here that sounded simliar to my problems.
I've had my 4runner for...2 months now i believe, and knew the tranny was a little off, but i bought it from a master technician and was going ot have him swap it with a 5 speed for my. however, i never did.
When i leave it in drive from the very start it works fine for 1st gear, which usually puts me at about 15 mph. However, when it's supposed to go into 2nd it transfers into i'm not sure what with low rpms, and speed. I really ahve no idea about transmission problems so i'm not gonna try and guess on what's wrong with it here, so i was lookin for some help with this.
in the previous thread things about the solenoids were mentioned.
PS. for mine i end up just putting it in 2, which allows it to go from 1st to 2nd, then tapping it forward into D usually around 25-30, and it then appears to be in 3rd.
thanks
Old 05-19-2007, 04:14 PM
4runnerx3's Avatar
What size tires do you have? Does it act up with the power ECT?
Old 05-19-2007, 04:54 PM
rooney's Avatar
i only have 31's on there and i'm not sure if it does this in power ECT also, i drive in normal
Old 05-19-2007, 05:03 PM
4runnerx3's Avatar
If you're missing/skipping 2nd gear, first thing to check is solenoid No. 2.
Old 05-19-2007, 06:04 PM
rooney's Avatar
i know this sounds inexperienced, that's cause i am. i haven't purchases fsm's yet so where can i get a diagram that shows where the solenoids are located in the car and which are which. thanks
Old 05-19-2007, 06:10 PM
4runnerx3's Avatar
First thing, does the OD light flash while driving?
Old 05-19-2007, 06:29 PM
rooney's Avatar
I'm checking that tonight when i go out. i never knew about the flashing codes. If it is, can i just go off of what was said in the other recent post about tranny problems?
Old 05-19-2007, 06:42 PM
4runnerx3's Avatar
If you have any codes, the OD light will blink while driving.
Ground the small square plug beside the coil. Switch ignition on, don't start, make sure the OD button is on, and the light will blink.
here are the codes.
Old 05-20-2007, 03:16 PM
rooney's Avatar
i would like ot check for the codes but it seems that my OD light isn't working. Mine is located just under next to the stock stereo deck location, and with the car on i can flick the OD button on and off but the light stays off. any common problems or suggestions with this?
Liadrin
04-25-2022 02:54 PM
Liadrin
09-01-2015 06:44 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: transmission problems
