transmission pan question
Old 05-12-2008, 12:34 PM
91YotaExcab's Avatar
i cant get the pan down all the way do i need to remove the sway bar to get it out? or am i missing something? i doesent seen to want to slide either way because something inside the tranny is blocking it
Old 05-12-2008, 12:36 PM
sorry its a 91 3.0 4wd
Old 05-12-2008, 12:42 PM
mt_goat's Avatar
Yeah if you don't have a suspension lift you would need to take the sway bar off. What's hanging down is the ATF filter/pickup.
Old 05-12-2008, 05:11 PM
js9924's Avatar
My 94 was easy just drain it and take out the bolts. No issues with a sway bar its no where near my tranny pan. Make sure you clean the magnets in the pan, if there are none get some they can save you some headaches. also get the good gasket no cork.
Old 05-12-2008, 05:18 PM
Ya you have a t-100 i have a pickup. my sway bar is about 2 inches below the pan. Im just gonna take it off another day. the bolts for it are VERY seized on
BeMiceElf
10-10-2015 09:40 PM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
rchavis
07-27-2015 07:41 AM
mYnAmEiSmUd
07-20-2015 06:48 AM
Quick Reply: transmission pan question
