transmission in out, what else to fix??
Old 04-23-2007, 07:38 PM
Jonnym's Avatar
i pulled my trans to change the rear main and to swap the clutch. what else should i change out??
thanks
jon
Old 04-23-2007, 09:13 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
The clutch fluid, if it's dark. Unless the master and slave cylinders are not working, no need to do anything with them.
New pilot bearing...throwout? The retainer clips for the throwout bearing....on the clutch fork. Those clips may be gnarled or even missing.
Check pedal adjustment.
That's all I can think of.
http://personal.utulsa.edu/~nathan-b...sm/clutch.html
chuckross1957
06-28-2019 10:19 PM
Tigbucket
07-30-2015 07:29 PM
HookahRoo
07-20-2015 07:06 PM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: transmission in out, what else to fix??
