Transmission not shifting, electricial probs?
Old 10-12-2010, 03:31 AM
lil_man's Avatar
92 p/u 22re, automatic, ext cab, 193,000 miles
Shifts fine through the first gears, When tryin to go into the last gear, it take along time. (Engine rpms are really high). But, after about 2 mins, I hear a clicking noise by my left foot, then it shifts. Sounds like its coming from the fuse panel. Any help??
Old 10-12-2010, 05:08 AM
rustypigeon's Avatar
The transmission only has 4 gears. I can't think of anything related to the transmission near the fuse panel that would make a clicking noise. What I would do first, is a manual shifting test. This will allow you to disconnect electronic control and see if you can get into 4th gear (which is also called O/D) using the manual shifter.
Use the search function and type in "manual shift test". You should find plenty of info on how to do it.
Old 10-12-2010, 08:39 AM
lil_man's Avatar
ok, thanks
Old 10-18-2010, 03:21 AM
lil_man's Avatar
Any other sugestions?
Old 10-18-2010, 08:27 AM
What were the results of the manual shift test? This test will determine whether the problem is electrical or mechanical. We will therefore be in a better position to give you suggestions.
Liadrin
04-25-2022 02:54 PM
crammit442
7
11-29-2017 12:30 PM
mskalmus
05-28-2017 07:51 AM
Liadrin
09-01-2015 06:44 AM
Gio8
08-27-2015 12:14 PM
Quick Reply: Transmission not shifting, electricial probs?
